Headlights issues
2005 S430
Headlights issues
Hello
Could someone recommend the best headlight bulb for my 05 S430. They are the halogen ones. So far I'm on my second set and I can only see about 2 feet in front of me. I have to pull the headlight switch to the out position to see any further. I went to a shop to see if they had any idea. They said that I have to replace the whole headlight assembly.
Have an aftermarket hid kit put in
most car stereo stores can do this if you need professional installs
or you can buy a canbus h7 hid kit on Amazon eBay and do it yourself
edit :corrected to h7
SPONSOR/MBworld Guru
You need an H7 HID conversion kit, not D2S. Let me know if we can help you out. We carry high end Morimoto HID canbus conversion kits that will be plug and play
2005 S430
Thanks for the quick responses. Are the conversion kits easy to install or will I be better off getting them professionally done? Also Any recommendations on which ones to get from Amazon? There are so many to choose from and I don't want to get the wrong ones
Don't try those price lower than $75, try to see the description if ballast made by Japan or Germany. For those ballast made in China, sometime last a few month, sometime last a few years, been there done that !
2005 S430
I found this one on Amazon (55 Watt CAN-BUS HID Conversion Kit (H7 Single Beam, 6000k Crystal White)) It is about $140.00. I also got a quote from a shop that will do it for about $200.00. It looks easy to do, but with a shop I will have a warranty if anything goes wrong
If you're going to have a shop do it and they also sell hid kits I would recommend you buy the part from them , and make sure they offer a good warranty
if you buy your own parts , most shops will not redo the labor for free, when the parts you supplied fail
and yes there is a high failure rate
'04 Cobra & '04 S430
I just have to ask - but isn't this as simple as just finding a spot for the ballast and then just changing a light bulb? Do most find a way to wedge the ballast inside the headlight housing or do you drill a couple holes and mount the ballast outside of the headlight housing?
I'm thinking of doing this myself very soon. Seems like I can't see squat at night until I turn on the forward fog lights.
2005 S430
Update:
I was out of town last week and while I was out there I decided to get the conversion done. When I got back I noticed that they are about the same brightness as before. Will changing the bulb from 5000k to 6000k make any difference, or is there anything else I should do?
5000k will be brighter than 6000k
the higher k the Less bright
they become . They turn more blue and more dim
your lenses may be cloudy , have them polished . Most full service car washes that detail cars can do headlights restoration
