Airbag Modification?
Old 02-18-2017, 01:12 PM
jdhooper1963's Avatar
2006 E320 CDI
I have a W220 steering wheel with the one center connector on the airbag. Can the airbag be modified to the two connector style with the green and yellow connections to be used on my 2006 E320 which is a W211?
Old 02-18-2017, 06:26 PM
wallyp's Avatar
2003 S500 2007 GL450
I seriously doubt that you can safely modify an air bag - that sounds pretty dangerous. You might try to see if a W211 air bag will physically fit into the W220 wheel. A better approach would probably be to try to find a used W211 wheel that is the style that you want.
Old 02-18-2017, 08:18 PM
vmystikilv's Avatar
Range Rover
No
