fuse chart diagram (no audio)
Old 11-27-2012, 08:26 PM
Augr's Avatar
2006 s class 500
I seen the post for "no audio" and gave the fuse chart diagram (mine doesn't have the chart also) for a 2000 s-class 500; mine is a 2006. Does anybody know if they'd be about the same or could somebody post the 2006 fuse charts diagram. I have no audio for all of command. tyvm
Old 11-28-2012, 10:16 PM
trombone's Avatar
2002 S430
The problem is more likely at the fiber optics connection than at a fuse.
You may try this: lift out the CD changer, disconnect and reconnect tight the fiber optics. It helped me.
Old 11-28-2012, 10:18 PM
trombone's Avatar
2002 S430
But I am not sure id the fiber optics is stil relevant for the year 2006. If not disregard what I wrote. Sometimes disconnecting an reconnecting the battery may help.
Old 12-04-2012, 11:22 AM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
Augr, see http://www.benzworld.org/forums/w220...tart-here.html for both fuse diagrams (the '05 and '06 are the same) as well as for help in troubleshooting audio problems.
Old 05-27-2014, 12:37 PM
Augr's Avatar
2006 s class 500
Augr
thx all for the helpful info - what i eventually did, was, since the problem "happened" 'bout the time i signed-up for satellite radio - simply cancelled. Walla, fixed 'n don't think it was coincidental - no problems since!
Now, would like to replace the fuel filter on my 2006 s500 4matic if there's any links/videos out there would appreciate them (not the most computer savvy) thx again.
Old 05-29-2014, 10:29 AM
fxdeebee's Avatar
2006 S500 base
Try this..
Quick Reply: fuse chart diagram (no audio)
