Using washers to drop the car.
Old 11-14-2011, 11:24 PM
  #101
w4sim's Avatar
S55K AMG
Ok, once again this threads coming to the top.
Firstly, a big thanks to fkong777 for starting this thread, a cheap way of lowering that does exactly the same as the expensive stuff but for literally a fraction of the cost . . . . . . a man of after my own heart!
But im wanting to try this on my 2004 S55, with ABC.
This may sound rather silly, but since i dont know my way round the car yet (only had it a couple of weeks), can some one please tell me where the front adjustable links are? Are they at the top of the wheel arch or towards the bottom of the strut?
Once i know what im looking at il be able to do this quite easily.
Not knocking our man who started the thread but a few basic pictures of the process would have done wonders.
Thanks anyway.
Old 11-28-2011, 09:08 PM
  #102
classyS's Avatar
2001 S430
washer update - no grinding needed
sup gang, resurrecting this thread with an update on lowering car.
1. locate original ride height sensor arm / ball joint
2. longer screws with nuts and alot of washers.
3. L bracket*
pictures -
dont forget to add washers (original method)
happy screwing!! enjoy!
Old 11-29-2011, 01:31 AM
  #103
w4sim's Avatar
S55K AMG
2004 S55 AMG with ABC.
Ok, iv found the ride height sensors and i know how to do the fronts, no probs.
The only problem is that my car has 2 sensors at the back aswell, one on each side, how do i adjust these, with washers aswell? If so where do i place the washers on them?
All along this thread it seemed like there would be something in the middle of the car at the back that needed to be moved a few notches, but now it turns out mines got individual sensors on each corner.
Old 11-29-2011, 01:54 AM
  #104
Viet_Amg408's Avatar
Pinto
Thumbs down
This kind of mod is not safe. What if the washers or the nuts come off?
Just spend $300 buy the links and get it right.
Old 11-29-2011, 10:28 AM
  #105
classyS's Avatar
2001 S430
this for the cheap folks or perhaps the curious one, i took these pics as a tutorial for a buddy who cant understand in words, yes its dangerous and adding more screws and nuts extends the risk of failing (more failure points) so i suggest people here to use this method at your own risk!!
Old 11-29-2011, 10:38 AM
  #106
classyS's Avatar
2001 S430
dude, you own a 04 s55!! dont go cheap route with this car, i have a 01 s430 so i keep it cheap until i get a better one but honestly get links or program it!!!
Old 12-03-2011, 05:07 AM
  #107
SFBIGBODY415's Avatar
2000 mercedes benz s430
I am using the washers but after reading all this I went ahead and ordered the links for my car.
Old 12-03-2011, 02:11 PM
  #108
Das Geld 2's Avatar
SL55, S500
Airmatic links are much cheaper than the ABC ones.
Im using Adjustable Air Ride links.
Old 04-18-2012, 03:40 AM
  #109
fkong777's Avatar
07 GL450, 91 NSX, 12 Prius
OP here,
Update. Last pictures of the car. Traded for a GL450
no issue with shocks. never failed.
Wheels were minutes from coming off the car.
for the ones advocating links. the washer and bracket are not unsafe. It is not a stress link. it is merely for angling the sensor in reference to height.
Old 04-18-2012, 05:03 AM
  #110
adrenaline12055's Avatar
W220
Originally Posted by fkong777
OP here,
love those wheels, where did you buy them at? and how much? im planning on getting a set too. would you sell me yours?
Old 04-18-2012, 07:29 AM
  #111
Mrr hr3 are what those wheels are called. Look awesome!
Old 04-19-2012, 01:52 AM
  #112
fkong777's Avatar
Yes they are MRR HR3 20x8.5 and 20x9.5
It took some work to get the 9.5 on the rear.
Need a 10mm spacer the clear the rear brake.
also have to remove some material where the bumper and rear quarter meets.
the look is worth it tho. the rear concave more than the front.
Old 10-07-2012, 08:38 PM
  #113
Purple-220's Avatar
purple w220 s430
anybody make a Tutorial on this? step by step with pics?
Old 11-10-2012, 12:32 PM
  #114
adlerx's Avatar
S430
Yeah, I would like to see a bit more detail on this as well. Also any reports from anyone who has done this.
Old 03-31-2014, 04:18 PM
  #115
kingbolom's Avatar
GL450 / GSX-R / Acura RL / Acura TL Type-S
Keep on MODDING guys!!
The ride looks GREAT!
Old 11-30-2014, 09:41 PM
  #116
VMAX7's Avatar
2000 S430, 2000 S500 Both Brilliant Silver!
Excellent thread! Just saw it.
Old 12-01-2014, 01:30 AM
  #117
VMAX7's Avatar
https://mbworld.org/forums/s-class-w...g-aware-2.html
The OP of the linked thread had a false alarm, i put it here to give more background to this thread as it seems to be the inspiration for OP of this current thread.
Old 12-01-2014, 01:39 AM
  #118
VMAX7's Avatar
https://mbworld.org/forums/s-class-w...t-sensors.html
This is even better.
Old 12-01-2014, 08:21 AM
  #119
VMAX7's Avatar
Just played with the washer lowering method, i understand it now but I cant get the 10mm nut off the rod, the ball joint keeps spinning in the other end of the rod.
I used a long nose pliers to grip and hold the ball joint while loosening the nut but it just spins perpetually.
What exactly did u guys use on this? Im so close but yet so far..
Old 12-02-2014, 10:23 AM
  #120
rob_fed's Avatar
W204 C300 2010
I used a small spanner (wrench) that came with my kid's electric scooter. It is made out of stamped steel and cut out in wrench shape. I suppose an inexpensive bicycle tool would work too. From memory I believe the opening is 10mm.
Old 12-02-2014, 06:00 PM
  #121
VMAX7's Avatar
Great idea ill try that, thanks!
Old 12-03-2014, 09:31 AM
  #122
VMAX7's Avatar
So I just noticed that my passenger rear is higher than the driver side rear, and my ride height sensor arm adjustment thingy is rusty.
Id like to plug it out, spray it with electronic cleaner and plug it back in.
Plugging out the sensor w/o adjusting the arm any clicks will that cause the rear struts to collapse? Im apprehensive to touch it.
Worse case ill have to buy a new rear adjuster arm, if i can wd40 the rusty arm and make it like new then ill be happy.
Old 12-03-2014, 11:11 AM
  #123
Former Vendor of MBWorld
shardul's Avatar
2003 W211 E55, 2003 W220 S600
dealers sell the rear adjustable arms for about $ 30
Old 12-03-2014, 11:50 AM
  #124
wallyp's Avatar
2003 S500 2007 GL450
There is only one ride height sensor on the rear, so that shouldn't be the reason that the right rear is higher than the left rear.
Each front strut has a ride height sensor.
The ride height of each corner is individually adjustable using DAS (the STAR system).
Old 12-06-2014, 06:01 AM
  #125
Welwynnick's Avatar
2006 S600
I presume your car is Airmatic?
Is the ride height sensor attached to the sway bar?
ABC cars don't have sway bars, so they have two rear sensors.
Nick
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
Quick Reply: Using washers to drop the car.
