soft close doors
2006 CLS 500(sold), 2005 C230K, 2005 E 320,
kind of annoying soft close doors
Just trying to find out if anyone is a bit annoyed by the fact that the doors need to be shut a little more for it to be pulled in automatically.
my brother-in-law who has a BMW 750li also noticed it this weekend. He drove up specially to check out the car and that is the first thing he noticed.
I knew it all along, but wasnt going to point it out to him. He's swears by BMW.
I noticed this when I was checking out another S Class that was in the dealer lot.
Please let me know. My dealer says its normal, but I am not so sure now.
'07 S550, '03 FXDWG
Originally Posted by VRCL55
This is a safety issue. Can you imagine a child closing the door and getting his/her fingers stuck when the system starts pulling?
That was one of the first "flaws" we noticed on the new S as well. Coming from the W220, the new S requires you to push (or pull) the door a lot harder for you to hit the trigger point for the pneumatic assist. I believe the reason for difference between the W220 and the new S is because the doors on the new S have unlimited stop points. Meaning, the door will hold whatever position you open it to. As a result, the door has no spring that pulls the door closed, so I end up not pulling the door closed hard enough. I'm sure I will get used to it but I hope there is a way for MB to adjust the trigger point because I find that a lot of the time, my door hasn't fully closed.
Pointless
Well this makes the pneumatic assist pointless if the door needs to be that close to the threshold. On the W140 and W220, a simple push on the door from the last stop point would give the door enough momentum to latch on. Now it appears that the W221 requires too much attention.
valid points
Thanks for the opinions on this. They all seem valid, but again most of the time I am reopening my door to just close it. I mean I'd rather slam it which mercedes prefers you to do, because the "thunk" sound is something benz started first, as far as I remember.
But, regarding the fact that it has variable opening points, so does the 7 series and it pulls the door in at the first click.
Again, considering the children, I guess it seems valid too. I mean I have children so I better take a better look why Mercedes decided on this.
Thanks for the responses to the thread.
Yes, I noticed the additional force needed also. We have driven off several times and had to stop because a door was open.
But on the other hand, the electric trunk closer is great! Its always taken way too much force to close the trunk on the '06 S.
Even on the W220 if you hit the first click way to light, it won't trigger the assist. But I would say 95% of the time it worked. On the new S, again moving from the older S that we were used to, initially I'd say almost half of the time I've had to reshut the door to get it closed.
As far as children issue, Mercedes has had this feature since like 1992 or something. I don't see why children would be an issue now.
DBGator: The trunk closer has been an option since at least the 2001 S class. But, I agree with you, if you didn't get that option, the trunk was pretty difficult to close.
98 Ford Explorer Limited, 2007 S550 LE
Originally Posted by Germancar1
Is the new S really that trouble free to the point is seems as though some are looking for some sort of problem when there really isn't one??
M
M
