MBUSA W221 Bulletins to date
#176
Is there a TSB or anything for vibrating LED strips in the door panels? I just skimmed the thread and don't see anything. The problem seems to have been reported 100's to maybe 1000+ times online.
#177
LI for Seats
Konig is there an LI for Seats. I found LI91.10-P-053443 on another page said it covers 2007-2013. i get a cracking sound when someone is in the passenger seat. I have the ELW warranty hopefully it is covered under that.
Thanx
Hd
Thanx
Hd
#180
Received 4,416 Likes
'71 Pinto
Recall Campaign 2017030015 APR17 - 2006 through 2016 117, 164, 166, 190, 204, 205, 207, 211, 212, 218, 221, 222, 231, 253, and 463 vehicles that received a control module coding update while at dealer between December 3, 2016 and December 5, 2016 might not function as intended dealer will update the affected control modules.
#181
mercedes-benz s320 cdi 2008
Hello,
I'm new here on the forum.
I have a s320 from 2008 (w221) and would like to know how do I access the secret menu or engineering mode and watch video while driving?
#182
'71 Pinto
LI54.65-P-066284 MAY17 – Vehicles with reversing camera (code 218) or 360 camera (501), see attachment.
The following 2 users liked this post by konigstiger:
M-a-x-G (09-06-2017),
riv-stage 1 (10-12-2021)
The following 2 users liked this post by Gabe Robinson:
dlafever (02-26-2018),
riv-stage 1 (05-02-2021)
#184
#185
'71 Pinto
LI82.85-P-069468 MAR19 – 221, 216 with NTG3 COMAND shows wrong date, time on the analog clock and cannot be altered.,Reset the instrument cluster control unit using Xentry however, bulletin does make clear if reset is at cost, or goodwill remedy.
#186
- Complaint resolved until next required time change!
- Customer does not have any navigation function restrictions! - The date cannot be changed!
It is unfortunately not a fix for the date issue. If one reads the logs of the navigation system, it fills up quickly with "EPOCH time is more than one week off."I feel if they really want to fix this for their customers, they will release a telematics update and fix the defective software.
#187
'71 Pinto
Service Campaign 2019040001 APR19 – 2012-2014 117, 166, 172, 204, 207, 212, 216, 218, 221, 222, 231, 251, 463 ECU Malfunction Indicator Light displayed while no fault is present in the control unit, dealer will update ECU software. Approximately 210,440 vehicles are affected.
#188
#189
'71 Pinto
#190
I am a new S550 owner WDDNG7DB1DA504164.
Can you please help me get a VMI?
Does Model Year 2013 have any current issues/Service Bulletins i should have addressed?
thanks so much in advance
#191
UPDATE: went to dealer, and got this completed.
Thanks again!
Thanks again!
- Campaign No. 2019040001 - Update engine electronics (ME-SFI) control unit software.
#192
'71 Pinto
LI46.35-P-071461 JUL20 - All models w/electric steering knocking noises when driving or steering, check wear of tie rod outer joint.
LI46.35-P-071462 JUL20 – All models w/electric steering knocking noises when driving or steering, check wear of tie rod inner joint.
#194
'71 Pinto
LI35.30-P-058566 SEPT20 – 171,172,203,204,205,207,209,211,212,213,215,216,21 7,218,219,220,221,222,223,230,231,238,253,257, 164,166,167,292,293 single throttle lift-off clunking noise from the side shaft when moving off (audible at the outboard end) noise is heard once in each instance when changing direction of travel. If the complaint is eliminated by experimentally loosening the outboard collar nut (by 1 turn), the problem is due to cracking of the microweld between the wheel bearing inner race and the joint housing of the side shaft. The collar nut must always be replaced after being loosened. Coat contact surface of side shaft with wheel bearing with Molykote paint (MB part # 0009890152).
LI33.30-P-056665 SEPT20 – All Mercedes-Benz cars with front-wheel drive and 4x4 vehicles single throttle lift-off clunking noise from the side shaft when moving off (audible at the outboard end). The clunk is heard once when changing from forward to reverse (and vice versa). If the complaint is eliminated by experimentally loosening the outboard collar nut (by 1 turn), the problem is due to micromovement in the connection between the wheel bearing inner race and the joint housing of the side shaft. The collar nut must always be replaced after being loosened and must be tightened to the specified torque. Coat contact surface of side shaft with wheel bearing with Molykote paint (MB part # 0009890152).
LI27.50-P-049281 SEPT20 – 722.9 transmission when changing gear range from P to D, harsh engagement may be noticeable, engagement sequences for N-D and N-R must be taught in again as follows (always remain in the gear ranges N/R/D for at least 5 sec): start the engine from cold, shift 5 times N-R, shift 5 times N-D -> warm up transmission to 40°C and while doing so, exceed a speed of 30 mph at least once. Shift 5 times N-R, shift 5 times N-D -> warm up transmission to 70°C and while doing so, exceed a speed of 30 mph at least once. Shift 5 times N-R, shift 5 times N-D.
#195
'71 Pinto
LI01.40-P-057996 JUL/21 – 152,157, 278 engine up to vehicle production DEC2013 coolant leaking into the engine oil via the molded seal between the timing case and the cylinder crankcase, replace seal.
CaliBenzDriver (04-18-2023)
