w221 Headlight/City Light Bulb Replacement
Old 06-05-2010, 08:52 PM
bensitto's Avatar
S550, R350, GL550, ML63 AMG
Exclamation w221 Headlight/City Light Bulb Replacement
Does anyone know what the best way to access the headlights and city lights to replace them with 6K xenon and LEDs?
Passenger might have enough space to change it but the driver side has zero space. I'm thinking the wheel well might be the way?
Any help would be appreciated!
Old 06-05-2010, 10:37 PM
famous550's Avatar
S550, 2006 Range Rover Sports Supercharged
Changed all my bulbs in the headlights, The bumper has to come off to change any light.
Old 06-10-2010, 10:39 AM
vintagefefe's Avatar
a car
No need. Jack the car up. Remove wheel liner and feel your way around.
Old 06-27-2010, 10:12 PM
shellshock's Avatar
2001 Mercedes S500
The Thomas J (03-25-2022)
Old 08-09-2013, 06:18 PM
S500 Man's Avatar
White S63 AMG W/Designo Interior
Seriously?????you have to remove whole bumper???
Old 08-09-2013, 07:19 PM
mb techman's Avatar
CLA45
Old 08-09-2013, 07:22 PM
S500 Man's Avatar
Cant I just remove winshield washer fluid reserve and coolant reserve box to side??
TKinz (Today)
Old 08-10-2013, 01:56 AM
kalortpor's Avatar
S550
The owner manual specifies removing the washer fluid reservoir, but not for the main bulb (basically says "don't touch that!" for headlights). It will still create more space if you do move it.
I moved to Osram Xenarc CBI 5500K (best bulbs I believe, the Ultinons have great color but just too dim to wow), and I went through the wheel well. If jacking up the car is a problem, then you can just turn the wheel all the way to one side (you may need to do this a few times, some screws were only accessible one way, but then I had to turn the wheel to the other side to have room again).
You don't need to remove the wheel well completely, it's pretty sturdy and you can move the front out of the way and then hold it to the side. I was careful with my bulbs and practiced a few times with the old bulbs to not touch anything or accidentally scratch them on surrounding parts while manuevering them in. It just takes a little extra time and patience.
As I like to remind people whenever I get the chance, please torque your lugs to 150NM (110ft/lbs).
Old 08-11-2013, 12:14 PM
bensitto's Avatar
Fastest way is raising your car via airmatic, turning your wheel in on the side you need to replace the bulb, then unplug the inner fender lining pins and pull back the liner to access the lights. Takes 10-15 minutes per side.
For replacing the headlight, wheel needs to come off. Same process but put a jack under the side that needs to come off and remove the wheel. Add 5 minutes for removing and tightening the wheel.
Not too bad, but MB got smart and added a access panel in the fenders now so you don't need to pull the liner out on Newer models.
Old 08-11-2013, 07:26 PM
mb techman's Avatar
CLA45
Old 08-11-2013, 11:16 PM
bensitto's Avatar
I've removed the bumper on my car once, took me some time to figure it out. Do you know of a DIY on how to easily remove and replace it? I'm sure it would be helpful for all they guys here. Thanks!
Originally Posted by mb techman
just an FYI, its really not that difficult or labor involved to remove the front bumper.
Old 02-24-2015, 08:38 AM
tallermanberry's Avatar
mercedes s320
PLEASE DO NOT REMOVE BUMPER!!!!
To change the bulb on the drivers side, you can just slide your hand down and change it, I am over 6 foot tall and I have big hands, and yes it is tricky but can be done
On the passenger side, just remove one screw for the screenwash container, you do not need to undo the pipes - just flip it up and you will have easy access
All the best
mercedesbenzs55 (05-29-2016)
Old 07-28-2015, 08:10 AM
bkdaman's Avatar
2013 mercedes s 550
how do you replace xenon bulbs on 2013 mercedes s550
Old 07-28-2015, 02:51 PM
njsdavis's Avatar
08 S550 4Matic AMG Package
I want to change my bulbs also. Been looking at changing the side marker, headlight, and another small one inside there (not sure what to call it). In addition getting in there to change it, What brand and color is most reliable and give the best look. I have already changed ALL interior to LED and license plate to LED.
Old 07-28-2015, 09:18 PM
KNBS550's Avatar
Mercedes-Benz 2007 S550, 2012 S550 4-Matic, 2015 GL450
Search for this post. Should've named it something else, but here it is...
W221 HID Bixenon Headlight Bulb Replace DRIVER SIDE
Old 07-29-2015, 09:33 PM
kiddkynetik's Avatar
S550
I've changed the side marker (T10) bulb already but i had a hard time with the turn signal. I tried for a bit but finally quit. If you figure that out please let me know. How i got to that was behind the bumper and through the fender and just reached up into it.
Old 07-29-2015, 11:59 PM
KNBS550's Avatar
I don't think you need to remove the bumper at all to change the side marker. Instead, remove the front wheel well lining inside the fender. The plastic lining is flexible and is held in place by a handful of circular clips that can be popped out with a flathead screwdriver. Once you pop out the clips, just pull the liner to the side to reveal the area behind the bumper. Have the wheel turned to one side or remove the wheel entirely if it gives you better access behind the bumper to get at the turn signal bulb.
Old 07-30-2015, 06:00 AM
WHPH28's Avatar
Depends on the weather
All you have to do is pull the fender lining back just enough to get your hand in there. I changed mine a while ago.
Old 08-16-2015, 05:19 PM
popsrus's Avatar
W221 Mercedes S550 4 Matic , Range Rover Sport , Fiat Trekker
w221 Headlight, Running and Foglight access
Guys here is a simple way to get to all the W221 headlights, fog lights and bulbs. Dont take off the bumper not needed. First remove the wheel and jack up the car. You can do this using your own tire change gear in the trunk. The internal wheel well plastic needs to be removed first. Very simple. First three aluminum bolts on bottom of car on each side. Next remote the three plastic pop nut push ins on the front of the wheel well. Take the little black stud all the way out and then remove the expandable part. There are also three plastic nuts one on a post in the front portion of the wheel well and the other two on the back panel they are simple to find once you try removing the wheel well. Whole unit pops right out to expose the entire lighting assembly system on both sides, Driver sides a little tricker there are several cables in front of the HID door but you can simply move them to the side, I updated my HID, Fogs and running lights in a matter of minutes. Here is a pic of the exposed area once you take out the plastic wheel well liner.
The following 2 users liked this post by popsrus:
Lexozz (02-08-2020), rsr911 (04-07-2017)
Old 08-17-2015, 08:56 PM
jiceoo's Avatar
2015 S550 and 2014 GL 550 gone but not forgotten: 2006 ML500
Well done popsrus, very useful.
Old 08-19-2015, 11:00 PM
Nuru's Avatar
S350 BT 4MATIC
Yep that makes it very easy
Old 09-09-2015, 02:29 PM
MBenz07's Avatar
2016 S550
Thumbs up headlight was flickering, changed both bulbs in 30 min
Thanks for all who posted to this thread. I had driver side headlight begin flickering and read here that I needed new bulb. Didn't want to give dealer any more of my money, so ordered D1S on ebay and removed front tires. removed wheel liners and changed the bulbs with no problems. I upgraded to the 6000k and my lights are so bright and clear now. No more flickering and doing it myself impressed the wifey.
Old 09-09-2015, 05:15 PM
MonroeHandyMan's Avatar
2007 S550 4Matic 2009 ML350 4Matic
My left low beam just went out. I have to change it too. MBenz07, the D1S, were they from Innovited? I saw a pair of 6000k for $29.99 on Amazon.com. They dont specify what car they are for. Not sure if they are universal. I was also thinking of going up to the 8000k or is the 6000 enough? I want to make sure I get the right bulbs.
Thanks,
Anthony
Old 09-09-2015, 06:15 PM
MBenz07's Avatar
2016 S550
@MonroeHandyMan, no I got mine from eBay. Got them in 4 days, free shipping
Old 10-09-2015, 03:20 PM
multimillboy's Avatar
2022 Mercedes S500, 2021 Suburban Duramax
@popsrus thanks for the instructions. Was able to complete the job fairly easily. I used 6000k bulbs, brighter and no more flickering.
Quick Reply: w221 Headlight/City Light Bulb Replacement
