Sign in using an external account
| S-Class (W221) 2007-2013: S 320 CDI, S 350, S 450, S 500, S 550, S 420 CDI, S 600 |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: S class
Airmatic compressor malfunction after being rear ended
#2 |
Drives: 221.122 & 212.025 & 204.089
I don't have experience about this (being rear ended
) but if the accident was recently, the compressor could not have worn out between the accident and now.You are right that a leak would eventually kill the compressor. If they changed the compressor now, the leak is likely still there. They should have checked the car for leaks and then you could have tried to figure out if the leak had anything to do with the accident. |
#3 |
Drives: (1960) 300d, S550 AMG S500 S600 560SEL
if your car had a rear end collision and did not reach the suspension area, then the accident could not have any thing to do with your malfunction warning, the relay and pump is a common problem with this series, have a leak test first then check the relay and sensor if all are functioning right, always clean all the contact point and apply contact cement when reinserting the socket to make sure all the contacts and electric current is flowing properly. the event is coincidental, you may want to post some picture of the collision point and further evaluation and or suggestion may be rendered. Any insurance will never pay for such a claim unless you try to scam them.
__________________
| Tags |
| airmatic, benz, charge, check, class, compressor, cost, damage, ended, labor, mercedes, mercedez, price, pump, rear, w221 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
