Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > S-Class (W221)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 05-07-2012, 10:11 PM   #1
Drives: 2010 S550
Engine Coolant Loss 2010 S550
Last week I got a "Check Engine Coolant" message/alert displayed briefly after starting the car in the morning (engine as cold as it ever gets in Hawaii). After engine warmed the display cleared, engine temp normal and no indication of a problem throughout the day. Debated simply adding a little water, but decided to go with the MB recommended spec no. 325 (P/N Q1 03 0002) Anti-Corrosion/Antifreeze Agent from the local dealer for ~$38/gal.
It took about 0.8 quarts of fluid to bring the level just above the full (cool) tab in the surge tank.
Now I'm just wondering if its common to lose minor amounts of coolant over time? I've had the car 1.5 years, driven 75/25 city/highway) and 13,000 miles; one "A" service completed last December.
I did a search of the forums and the net and it didn't seem to be a common issue...
To remove this ad, register today or login if you already are registered!
chuck57 is offline   Reply With Quote
Old 05-08-2012, 12:56 AM   #2
desired_speeds's Avatar
Drives: 02 E55 & 04 E55
Send a message via AIM to desired_speeds
Its normal to need a very small amount of coolant over time. Even if the car isn't leaking.
__________________
W210 | W211
FOR SALE:
(2) two w211 OEM heat exchangers. will take best offer!
desired_speeds is offline   Reply With Quote
Tags
07, 2007, 2010, 325, antifreeze, common, coolant, issues, leaks, loss, mb, mbz, s550, sign, temperature
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
