Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > S-Class (W221)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 05-09-2012, 07:36 PM   #1
Drives: 2007 S550
Torque Converter or Transmission Pump
Hi Guys my transmission is making a howling noise in park and low speeds, my indy mechanic told me its the transmission pump but dealer said there is no pump just the torque converter, is this right.
Also dealer quoted me $2400 for converter, i've seen them online for $1200.
Has anyone replaced their torque converter, how much did it cost.
Any input appreciated
To remove this ad, register today or login if you already are registered!
604benz is offline   Reply With Quote
Old 05-09-2012, 09:15 PM   #2
Drives: 190D, 190E 2.6, C240, C43, C220cdi
Sounds like your dealer needs a lesson in the inner workings of a automatic transmission. Of course it has a oil pump!!!
Howling noises from the convertor housing is usually the oil pump bushings, it's usually loudest if you listen to the oil cooler line from to the oil cooler.
Ausmbtech is offline   Reply With Quote
Old 05-09-2012, 09:49 PM   #3
Drives: 2007 S550
Thanks for that info, any idea if its an expensive repair
Old 05-09-2012, 10:15 PM   #4
Drives: 05 crossfire w/SL55 drivetrain installed by Rudy Compart Intake/Needswings best et-11.22 @ 126
Quote:
I have a spare, redbulljnky is testing it now, to make sure his is good or bad ,if he does not need it , i'll take 200 + shipping for it. I will try to get the part# from it in a few days, jim
amx1397 is online now   Reply With Quote
Old 05-09-2012, 10:17 PM   #5
Drives: 2007 S550
Any idea what a new one costs?
Old 05-09-2012, 11:44 PM   #6
http://www.google.com/url?sa=t&rct=j...vv4M90Bqyh9LRw
$700.00
Old 05-09-2012, 11:49 PM   #7
Gearbox out and disassembled for this job, quotes will vary.
If it's low milage and dealer serviced I'd approach them for a goodwill repair.
Old 05-10-2012, 03:24 AM   #8
Drives: 07 MBZ S550 Sport, 08 and 05 Smart Fortwo, 04 Dodge Sprinter, 00 MBZ S500 Sport, 87 MBZ 190E 2.3-16
Can also be both pump and torque converter ($325). In worse case, sometimes torque converter housing. Just changed mine last week.
What happens is the OE oil pump bushing fails and binds onto torque converter shaft which turns the oil pump ($500). Once that happens, the oil pump gears grind onto the torque converter housing ($600).
If your lucky you can sometimes sand down the burrs using a DA detailer sander or if you have the resource you can have the torque converter housing CNC milled.
This has happened to not just one, but all my Mercedes with 722.9 transmissions that I decided to start changing them myself.
Torque Converter 2212500502 (remanufactured) - Torco Enterprise - www.torqueconverter1.com ($325 shipped, no core required)
Oil Pump 7222700197 (latest rev.) (OE) - www.parts.com ($500 shipped) (you can also replace bushing with improved aftermarket bushing ($35) made by Sonax if the pump gears and housing are not damaged)
Torque Converter Housing 2112711501 (OE) - www.parts.com ($600 shipped)
Pictures is of the torque converter with spun bushing and torque converter housing off my 2007 S550.
I really think there is a design flaw with the oil pump bushing spinning off the oil pump housing. All my vehicles have been purchased new, and ATF changed at 1K then every 30K. I take care of my vehicles. I just accepted that it will eventually happen on any MB with 722.9 transmission regardless of care.
Next year when I purchase the W222 I will definitely purchase with extended warranty, one claim with the transmission will make it well worth it. Many will say your lucky to hit 80K miles and not have failure. I use to purchase these cars thinking extended warranty is not needed, I guess times have changed.
Good luck.
BTW, in my opinion this is one of the easiest cars to replace the transmission on due to the amount of room available around the bell housing (tool marks and scratches are unacceptable, should look untouched when completed). I being only a MB hobbyist/restorer and not a professional took 7 hours total removal/reinstallation on the W221. I'll post more pictures of the clearance and space I worked with to accomplish.
Torque Converter or Transmission Pump-w221-722.9-bell-housing.jpg   Torque Converter or Transmission Pump-w221-722.9-torque-converter-w-spun-oil-pump-bushing.jpg
josephpampliega is offline   Reply With Quote
Old 05-10-2012, 12:56 PM   #9
Drives: 2007 S550
Great info thanks alot, it's going into my indy shop for diagnostics on Monday, i'll keep you guys informed.
Old 05-15-2012, 11:38 PM   #10
desired_speeds's Avatar
Drives: 02 E55 & 04 E55
Send a message via AIM to desired_speeds
its not uncommon for 07s to get torque convertor problems. I don't think Ive seen any 08+ models have the issues though.
__________________
W210 | W211
FOR SALE:
(2) two w211 OEM heat exchangers. will take best offer!
desired_speeds is offline   Reply With Quote
Tags
7229, bushing, converter, converterhowl, damaged, enterprise, external, oil, pictures, pump, sl55, sprinter, torco, torque, transmission
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
