Sign in using an external account
| S-Class (W221) 2007-2013: S 320 CDI, S 350, S 450, S 500, S 550, S 420 CDI, S 600 |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Is Camber Caster adjustable on W221?
__________________
#2 | |
Drives: E350
Quote:
Here is a link to a detailed discussion on the W204 forum: Castor Camber/Castor Fluted Adjustment Bolts Question. I have also read that the referenced p/n, A 000 330 00 18 , also works on the E class, so it may be common across the lineup. They can be found easily online for far less than MB charges. Regards, Don
__________________
#3 | |
Drives: (1960) 300d, S550 AMG S500 S600 560SEL
Quote:
__________________
#4 |
Your tires may be getting worn out? So you might want to double check that. My car is pretty low, and I have no issues with a bumpy ride. Our cars dont use coil springs btw? The dealer is correct. Only the front is able to adjust and there's a company that makes a kit for it. They possibly have the rear also but don't count me on that.
__________________
| Tags |
| 2001, 430, adjust, alignment, camber, car, caster, club, ds, e320, kit, mercedes, problem, rear, suspension, toe, w221 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
