Sign in using an external account
| S-Class (W221) 2007-2013: S 320 CDI, S 350, S 450, S 500, S 550, S 420 CDI, S 600 |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 04 E W211
Auto dipping rear view mirror in reverse?
#2 |
Drives: 05,cl65;33ford3wc.
Im going from memory on my 05, the inst cluster display has enable features that need to be on, also it wont tilt unless the drivers/pass mirror positioner buttons on the door is left on pass position, an easy mistake to make when adjusting the drivers mirror.
#3 |
Drives: 07 S550
look at your mirror control. is it selected on L or R? make sure it's on L
__________________
rominl |
#4 |
Drives: 04 E W211
I've tried looking in the menu, i have everything enabled, still nothing.
I tried putting the mirror in L and it didn't move. Hmm, must be something i'm not doing here. Maybe it has to be reset by the SDS? |
#5 |
Make sure the passenger side mirror button is engaged, thats the right side button not left.
#6 |
Drives: -
#7 |
Drives: S500
Have found this( thanks Chris) in a thread on this W221 forum - but then the other way around for Aus.-
#8 |
Drives: S550, SL65 AMG
You beat me to it...
__________________
Chris The Swede ---------------- |
#9 |
Drives: 07 S550
yes sounds like you haven't programmed the tilt down position
__________________
rominl |
#10 |
The motor for the facelift part number A2218205442 is actually cheaper than the old one...I wonder if we should try one..? Not that my OEM one worked on reverse..
__________________
| Tags |
| 2011, 2218205442, 320, automaticdip, back, bmw323i, clk, interior, left, mirror, mirrors, ml350, move, rear, reset, reverse, reversing, view, wont |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
