Facelift Multifunction Steering Wheel issue
Old 07-24-2012, 11:44 AM
Prash's Avatar
2007 Mercedes S320
Just bought 2012 steering wheel, airbag and silver paddles, added to the car, everything plugs in and fits, but nothing works, no buttons, horn not working.
Does this need reprogramming or something else?
Old 07-24-2012, 06:27 PM
Anabolik's Avatar
S550 AMG
This is bad news for me too then, tomorrow I was going to replace mine with 2011 amg str wheel and new multifunction switches. A tech from Mercedes told that i must replace control unit too, i dont have idea. Waiting for now.
Old 07-24-2012, 08:24 PM
Prash's Avatar
2007 Mercedes S320
Am going to MB tommorow to find out next steps, will update here when I know more. Did speak to parts guy who said it is common for reprogramming after steering change, nothing about changing units etc.
Old 08-12-2012, 04:02 PM
Prash's Avatar
2007 Mercedes S320
Quick update......took it to MB, put facelift wheel on, still no joy with paddle/horn/button on airbag, message on STAR suggesting no comm between steering contol module with Wheel, ? check LIN line from N80 steering control mod. Unsure if this programming or wiring issue then. Wondering whether the electronics unit in the steering wheel need updating. Or perhaps other control units like the front SAM/CGW or SCM.
Sorry.....tried uploading pics but not appearing.
Any ideas? Thanks.
Old 08-12-2012, 04:11 PM
Prash's Avatar
2007 Mercedes S320
Ok, Here are the pics. Thanks.
Steering Wheel Facelift.
Without the airbag, the electronic unit with part numbers. Everything plugs into this so does this need changing to a unit compatible with my car W221 2007?
The STAR error message.
Old 08-12-2012, 07:22 PM
Chris The Swede's Avatar
W222 S63L, ML/GLE350
YOU CAN NOT INSTALL IT ON A OLD pre facelift CAR!!This is the same with as with W211! I have said this so many times one here and on PMs. Totaly different electronics inside the wheel. Nothing that can be programmed. Will never work. All you can do is Just sell it to someone with a facelift car. Hope no one else do this misstake from now on..
Old 08-07-2013, 07:55 AM
ymalghamdi's Avatar
W220_S600 V12 BiTurbo
Smile
Hi every one ,
I've installed steering wheel (facelift) on my car , All things is working fine , Here some picture:
Old 08-07-2013, 02:37 PM
Prash's Avatar
2007 Mercedes S320
Is your car 2006-2009? How did you make it work?
Old 08-07-2013, 03:11 PM
ymalghamdi's Avatar
Wink
yes 2006
Old 08-07-2013, 04:22 PM
ymalghamdi's Avatar
Smile
(Please forgive me, my ability in the English language is very weak, I use Google translation )
Initially there are four things related to the steering wheel:
1 - air bag.
2 - horn.
3 - Paddles.
4 - switches.
1,2 and 3 very easy and will work perfectly without any modification, just plug and play. But fourth item (switches), It's very difficult, accurate and it requires tools and professionalism,
If you have a desire to see the details, I will explain to you everything which would require me to raise many of the illustrations and the way the amendment.
Thanks ,
Yousef Alghamdi.
Old 08-07-2013, 04:28 PM
Prash's Avatar
2007 Mercedes S320
Yes i would be very grateful if you could show illustrations of how to get this new steering wheel working. Thanks in advance
Old 08-07-2013, 04:34 PM
ymalghamdi's Avatar
Ok my friend I will soon, maybe today or tomorrow
You are welcome,
Old 08-08-2013, 01:19 AM
Carters550's Avatar
S550
Please do so ..great find
You are welcome,
Old 08-09-2013, 05:38 PM
ymalghamdi's Avatar
Post Here we are :)
Well guys,
I am very sorry for the delay
Ok, As I mentioned to you earlier that there are four things related to the steering wheel:
1 - air bag.
2 - horn.
3 - Paddles.
4 - switches.
1,2 and 3 It's very easy and will work perfectly without any modification, just plug and play. But fourth item (switches), It's very difficult, accurate and it requires tools and professionalism.
(The first phase)
Here I will explain the three items above by the following photos:
If there any comments or queries, Please tell me.
Please Work carefully, focus and take a pictures of the important things for reference when you needed.
Six images below explain you how to remove the pin.
After that, install the new steering wheel with the application of the previous explanation and here we have finished the first phase, the three items that we talked about working well.
Note: You will see the AIRBAG SRS fault on the instrument cluster screen, You just need to erase fault by MB Star Diagnosis.
Move on to the final phase.
Old 08-09-2013, 09:58 PM
Carters550's Avatar
S550
Thank you ..very good instructions! how much did the steering wheel cost you ?
Old 08-09-2013, 10:22 PM
ymalghamdi's Avatar
Talking
Thanks...
Old 08-10-2013, 02:50 AM
Prash's Avatar
2007 Mercedes S320
Excellent review, thanks a million!!
What is the final phase?
Old 08-10-2013, 08:11 AM
ymalghamdi's Avatar
Wink
The final phase is (the switches), where we will integrating the old switches with the new and installed on the new steering wheel, Because the new switches system is quite different from the old and therefore we will have to integrate them.
I will explain this phase in detail in the next post.
And here are some illustrations (also See the attached file):
Old 08-10-2013, 08:48 AM
Atcpup's Avatar
S550
Chris, some people take that statement as a challenge
Hey ymalghamdi, thank you for taking the time to post that info. I know that took a lot of your time!!
Old 08-10-2013, 09:20 AM
marthyh's Avatar
S500
Great info !! Thanks ymalghamdi !!!
Old 08-10-2013, 09:54 AM
Prash's Avatar
2007 Mercedes S320
This is superb!!! Keep it coming, thanks
Old 08-10-2013, 12:56 PM
Sure all can be done but most often when they ask this is if it is just to intall it with no mods made.
Old 08-11-2013, 09:57 PM
ymalghamdi's Avatar
Post The final phase
Thank you all for your complement and support.
We will start now in the final phase, Please Follow the step-by-step instructions:
We finished and I will be happy to hear any question or inquiry.
Old 08-12-2013, 07:30 AM
Prash's Avatar
2007 Mercedes S320
Many thanks Yousef. Am going to give this ago next few days. Superb write up :-)
Old 08-13-2013, 03:43 AM
You should make these and sell these. Fantastic write up.
Quick Reply: Facelift Multifunction Steering Wheel issue
