Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > S-Class (W221)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 08-11-2012, 02:50 AM   #1
Drives: i drive them all, fast and hard
C service
so what does it entail. we have some 42000 miles on the w221 and it says we are due for C service
i couldnt find anything in the maintenance book about c service
To remove this ad, register today or login if you already are registered!
__________________
1985 500SEL Euro Nautic Blue - A Classic Beauty
1998 S500 Brilliant Silver
2001 S500 Almadine Black/AMG Sport Package - Smooth and Silky
2010 S550 Palladium Silver/AMG P2 - Refined and Luxurious
2005 C320wz Granite Grey/Fully Loaded - Sold and Missed already
2012 E63 AMG Iridium Silver - Performance Package
vdubpower is offline   Reply With Quote
Old 08-11-2012, 03:19 PM   #2
konigstiger's Avatar
Drives: '71 Pinto
Here is the service sheet - mileage / time elapsed requirements...
__________________
konigstiger is offline   Reply With Quote
Old 08-11-2012, 03:58 PM   #3
it doesnt specify A, B or C like they used to, which were usually oil changes plus a lot of checks...
usually it would alternate between the two A and B, ive never seen C
__________________
Old 08-11-2012, 04:16 PM   #4
Drives: '71 Pinto
Quote:
Originally Posted by vdubpower View Post
it doesnt specify A, B or C like they used to, which were usually oil changes plus a lot of checks... usually it would alternate between the two A and B, ive never seen C
C simply indicates “time to complete required services” since you are > 40000 in addition to oil change (normally alternates between A & B because of various inspections) - brake fluid change, ATF change, combination filter replacement, air filter replacement, etc.
__________________
Old 08-11-2012, 04:29 PM   #5
so at 50000 will they call it D and so forth
i guess either way there goes 1000 bucks
__________________
Old 08-16-2012, 08:38 PM   #6
Drives: 07 S600, 09 ML63
Just did "C" service and I've got close to 60,000 miles. Ran just over $400 at the dealership. Hoping they actually did everything and didn't just change the oil & filter and reset the indicator.
ULJets is offline   Reply With Quote
Old 08-16-2012, 09:08 PM   #7
what did your invoice say it included?
__________________
Old 08-16-2012, 09:39 PM   #8
Check tire pressures. Oil & Filter. Inspect Poly V-Belt. Corrected fluid levels where needed. Inspect parking brake. Visually inspect suspension, drive shaft & axle boots. Perform Battery test. Inspected air filters % cabin dust filter. Lubed hood catch & hinges. Lubed door hinges and sunroof guiderails. Check brakes and tire condition. Performed overall vehicle inspection per MB check sheet (whatever that means).
Old 08-16-2012, 09:51 PM   #9
so they basically did an A service which is an oil change plus checks. Usually that runs under 200 even in southern cali
__________________
Old 08-16-2012, 10:02 PM   #10
I went to Hoehn...MBofSD was a couple $$ less, $325 as I recall. But I've had nothing but bad experiences at MBofSD.
Tags
amg, cost, e63, ml63, s500, service
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
