S550 Air compressor fuse/relay location
S550
Does anyone know where find this I have a message that sayz MALFUNCTION^ with yellow car and up arrow. Back end of car is to the FLOOR help!
40 amp large fuse in box beside the master cylinder (just in front of windshield driver side). I had this blow twice last summer, changed fuse and nothing wrong since...not sure why.
S550
really!? ok ....well tried that! it isn't that. The fuse is fine but no response from the pump. Does anyone know all associated fuse and relay locations that have something to do with the pump/suspension? Im really trying to avoid taking it back to the shop as that this same thing happened before and they told me it was just "SOME WIRES" with really no other explaination and was charged 1k! I think they replaced a fuse or two and was back up and running..car took less than a day for repairs..i can change my own fuses for free!
Received 4,415 Likes
'71 Pinto
Compressor f56 (40A) https://mbworld.org/forums/attachmen...sam-fuse-5.pdf
Compressor relay B http://www.doc88.com/p-794921881968.html
In addition, check harness @ compressor.
(1960) 300d, S550 AMG S500 S600 560SEL
physically check the airmatic strut and see if the plastic cover of the strut have been blown open from the bottom then you have to replace the strut, no matter how much the pump pushes air into your strut it will just go out, the electric air pump have an automatic setting which will shut off after a few seconds in order to protect the components. The picture is a front strut, just to illustrate to you what to look for on your rear strut.
S550
Thanx Cool Lagoon and everyone else! But nope that wasn't it. Turned out to be a bad pump, or should I say a still good working pump, with burnt corroded terminals. The plug must have gotten too hot and melted the connecter. I had to replace the pump and connector and the car raised back to its height!
2009 S550 AMG sport pckg. 2014 Ford F-150 Lariat Supercrewcab
https://mbworld.org/forums/s-class-w...-pump-diy.html
Check this thread out if you get stuck. I did a DIY on how to do it. It's not hard
