There goes the panoramic roof!
S550
This doesn't seem like an uncommon problem on these cars....Well I first noticed a problem when opening the sunshade on the roof, it started doing the old "movement in intervals" bit where it stops every 1/3 of the way and I have to let go and press the button again.
Except once the sunshade is open, the roof will not! So I can't open the roof....However, I noticed that when I close the sunshade, once it fully closes, if I don't let go of the button then it starts the grinding/machine gun sound.
Since they are two separate drive mechanisms and the sunshade is clearly affected, could it be that a fault is being detected that doesn't signal the sunshade is fully open, thus preventing the sunroof from opening as it doesn't think the shade is open yet? I'd rather deal with a faulty shade than a faulty glass, though either one is preferable to BOTH being out of commission....I'm hoping this is the case as it appears to be the opposite problem an E55 had where it was the glass roof that was opening and closing in intervals, but then the sunshade wouldn't close!
I think best case I'm looking at headliner removal and at least one of those motors needing to be shimmed...I'd at least want to be able to rule out the sunroof itself, maybe by pulling the fuse it will let me operate the sunroof to verify it still functions?
