Start NO - Sound
Old 01-20-2015, 06:35 PM
brownbomber's Avatar
2008 S550 AMG
Start NO - Sound
I just accidentally interrupted my starting process during the button press. (removed my foot off the Brake) Now it won't chugg at all...
WTH
All lights come on and headlights work fine, etc.
HELP
Old 01-20-2015, 07:41 PM
DaveW68's Avatar
Location: Land of Political Criminals and Urban Shootings
2015 S550
Give it about 15 minutes & try again. If that doesn't work, you may want to disconnect the starter battery for a couple of minutes, rehook, then try again.
You can also try lifting out the starter button, insert the key, & start it that way. That should re-sync the system.
Old 01-20-2015, 07:45 PM
Garticus's Avatar
W221/S550
Disconnect the ground wire in the starter battery if you're gonna use this method.
Old 01-21-2015, 12:30 AM
2008 S550 AMG
pop-a-lock couldn't get it started with a high voltage starter battery pack. No chugging / turning sound still, but all lights are on.
I am leaning towards thinking it's the starter.
Old 01-21-2015, 01:46 AM
cmpcpro's Avatar
1956 Oldsmobile 98 Holiday, 2006 AMG S55, 2016 Toyota Camry Hybrid XLE
I'm pretty sure just releasing th brakes as soon as it starts turning over makes no difference nor would the car stop starting.. something else had to happen
Old 01-21-2015, 07:39 PM
2008 S550 AMG
Do you think that jumping the trunk battery will do the trick?
Old 01-22-2015, 10:55 AM
DaveW68's Avatar
2015 S550
Have you tried pulling off the starter button & inserting the key to start the car? Or perhaps your 2nd key?
Old 01-22-2015, 09:50 PM
Garticus's Avatar
W221/S550
DO Not try this. The battery in the trunk runs the vehicles electrical system.
The battery under the hood starts the car.
Possibly put a multi meter (set to DC volt) and see if you have more then 12v.
If so possibly take that battery out and get it tested to make sure it has sufficient cranking amps.
Old 01-23-2015, 09:25 AM
alx
alx's Avatar
The brake pedal signal is monitored only upon initiation of cranking. One the cranking commences the brake pedal signal is not monitored anymore.
So if your starter was cranking, but then stopped there is a problem unrelated to software. Rebooting the car should not make a difference. Check battery and fuses. In reality the car needs to be read and few actuations performed to pinpoint problem.
Quick Reply: Start NO - Sound
