19x8.5 S63 Style Wheels 35mm $649 from PowerWheels Pro
Former Vendor of MBWorld
Description: 19x8.5 S63 Style wheels
WHEEL SPECIFICATIONS
Price: $649
Offset: 35mm
Weight: ~28lbs
Hub size: 66.6mm
Bolt Pattern: 5x112mm
Finish: Gun Machined Face
Shipping: $85
WARRANTY
Our wheels are made at an OEM factory so we are proud to offer the following:
2 Years Finish Warranty: Many replica wheels finish can be sub par and the finish can crack or peel off. Since our wheels come out of an OEM process, the paint and clear coat thickness is similar to OEM standards.
Manufacturing Defect Warranty: The wheels are made in a low pressure casting process like OEM wheels and go through rigorous quality controls including 100% x-ray, leak and balancing tests. They are guarantied to fit on your car without vibrating or pulling.
Fitment Warranty: You don't have to know the technical specifications of the wheels your car takes, you can lean on our experience knowing what fits your car. If we get it wrong, we will support you as much as we can, or we will take full responsibility and give you a refund.
The wheels will work with your TPMS sensors and you can use your stock lug bolts. New chrome ones are available for $20 for the set of 20.
The wheels are in stock and we can also quote wheel and tire packages.
We do not make money on tires or on shipping, it is just a service we offer to our customers, we recognize not everyone has the time to drop off wheels and tires at their local tire store and waste half a day to get them mounted and balanced.
We will mount and balance them for you and take on the risk of getting it right. We have had many customers that called us after getting their wheels mounted telling us that the tire shop scratched them and asked for replacements.
You can always call us at 248 686 2035 if you have any questions.
Thanks for looking!
Many are interested in a 21" style factory wheel. Many feel 20" is too small for the S class body and 22" is way to big. I know most of this stuff made overseas but what are the chances of doing something in a 21".
Hi Jason,
Thank you for your post. We had this option in stock in 21" for months but we are currently out.
We will bring more in. We strongly believe in having something for everyone because of the exact reasons you mentioned. Sometimes the factory availability can be a little tricky but we try our best.
Thank you
Thank you
Hi Jason,
Thank you
Thank you
35mm offset would work in a 21", although the OEM offset is 43mm. I think the 21's look good from the side, but a 21 x 9" wheel is going to look awful tall and skinny from behind. I think a staggered with 21x11" rears would look more proportional. That is a beautiful wheel though in whatever size it comes in.
2008 S63, 2012 E550, 2005 E55, 2005 SL55, 2013 SL63, 2020 AMG GT, 1994, 1998, 1999, 2001 SL500
Hi Jason,
Thank you
Thank you
Would really be interested in this for an S63 in a staggered setup if available
Thank you for the responses guys, I apologize for the delay in replying, we didn't get the notifications in our inbox. Just this last post generated a notification for some reason.
Anyway, we are unfortunately out of the 21s at this point in time, the factory can make them in 21x9 also, it is a matter of having them available at the time we order our container so we can bring them in.
We currently only have the 824 in 20" square size which is 20x10, good for ML /GL, not so good for S Class.
If you would consider sticking with 19s we can do the ones posted here as well as the 828 style also in 19x8.5 35mm
Thank you
Thank you
Not on a W221, unfortunately I don't.
The S65 though had the first ones on, here is a pic I found online
https://images.search.yahoo.com/imag...hspart=mozilla
