Mid City remote starter and DroneMobile install...
Old 06-30-2015, 02:56 PM
Mike5215's Avatar
2016 C300
I'm having my Jason-sourced remote start and drone mobile installed today at my favorite audio shop. If things go as they typically do over there, soon I will be able to unlock my glovebox using my toaster.
Old 06-30-2015, 04:48 PM
jiceoo's Avatar
2018 GLS550 & 2015 S550 gone but not forgotten: 2006 ML500 & 2014 GL 550
Breakfast on the go!
Old 07-01-2015, 08:58 PM
Mike5215's Avatar
2016 C300
Picked mine up after the MidCity remote starter and Drone Mobil (allows remote starting and locking from your smartphone) install. Works perfectly.
Old 07-22-2015, 07:53 AM
bkdaman's Avatar
2013 mercedes s 550
works perfect on my 2013 mercedes s550 great job midcity and drone btw I have the premium service from drone.
Old 08-03-2015, 06:59 PM
manny26's Avatar
2010 Mercedes c250 4matic
where abbots would the AC Register be by the driver side window? i still need to re position my drone module?
Old 08-04-2015, 10:32 AM
snovvman's Avatar
I'm your huckleberry
"Register" is another term for air vent, so it is the air vent adjacent to the driver's side window. Once you pop open the side cover, you can reach up and feel the duct. That is where I located my module.
Old 08-04-2015, 10:36 AM
  #32
Jason B's Avatar
W140 Mercedes S350, W221 S550 sport
You mean the driver side fuse box cover?
Old 08-04-2015, 10:39 AM
  #33
snovvman's Avatar
Yes--how quickly do I forget--you must first remove the fuse block to gain hand entry. IIRC, the fuse block is held by one screw. Back that out and swing the block out of the way.
Old 08-04-2015, 11:20 AM
  #34
Jason B's Avatar
Ok, yea. I just had it out. It's TWO Torx screws of course. Not regular screws
Old 08-04-2015, 12:22 PM
  #35
snovvman's Avatar
It's all Torx these days! Torx and ball bearings that is...
Old 08-14-2015, 02:28 AM
  #36
manny26's Avatar
i got no driver side fuse box, i got one in the hood rear left corner and trunk only
Old 08-14-2015, 04:33 PM
  #37
Jason B's Avatar
You should have one. There is a panel that needs to be removed and you won't see that panel until you open the driver side door.
Quick Reply: Mid City remote starter and DroneMobile install...
