Torque converter or Turbo???
S320 CDI w221 2009
Here goes. My gears shift hard into all gears when stationery. When my foot is on brakes while I D the engine seems to rev higher and car is raring to go quickly.
Star diagnostic shows only fault as being (fault code 2592 001 component Y77/1 charge pressure positioner) described as Turbo actuator by indie garage..
However
My regular indie thinks it's the Torque Converter in the 722.9 GTRONIC gearbox/tranny. Others agree with him as turbo seems to be working fine. As do the gears while car is driving.
Help!!!
However
Help!!!
Or use Das-Xentry to see if any codes stored.
Check maintenance items filters spark-plugs are done timely if not do this first.
Check vacuumlines are ok no leaks etc then throttle-body, map and maf sensor for contamination.
