Do These CLS550 Wheels Fit on 2013 S550?
2003 Acura CL Type-S 6MT
image.automobilemag.com/f/43641018+q100+re0/2012-mercedes-benz-cls550-4matic-front-three-quarter.jpg
Without spacers or anything, not lowered factory height Etc.
Current and prior gen S and CL , and the 2008-2013 C Class share offsets. The CLS is E Class based and runs lower offsets by about 10mm. All modern MB passenger cars have the same bolt pattern and hub bore and a lot have identical faces so offset is often the only difference.
That said, you can still run CLS wheels. They'll sit 10mm closer to the fender lips. (Spacers won't be necessary, since they actually serve to lower offset.)
Probably not. The majority of S Class shipped with 19's stock , so when people upgrade they tend to either go aftermarket, or go to 20", or both. Do you have a line on a set of those for a good price or do you just like the look?
I actually purchased a set already and they get mounted on Friday most likely so hopefully they'll fit without issue and I'll get some pictures up!
I personally love the style and love the OEM look - so this is why the CLS 550 wheels were somewhat of a no brainer for me.
Yeah, they're a good looking wheel. They'll fit although they'll look a good deal smaller in proportion on the S Class than they do on the CLS of course.
Should have some pictures up shortly of the himalaya grey 19" CLS550 wheels on my pearl white S550.
Decided to go with a black version of the centercaps.
