Interior Creaks
Interior Creaks
Took my 550 in for warranty repair for rattles in the front door panels on bad pavement. They replaced the wood trim on the drivers side and applied lube to various touch points. The passenger side trim is on back order. At first it seemed to have been cured but now I hear the same noise again
One thing I did notice is that it was strangely worse in the morning and better after the car had sat outside all day.
Also when I go over larger single bumps, the dash / console area seems to make a creaking sound which is very annoying.
Has anyone had either of these issues and found a fix? Is their a TSB?
My model year is 2013
2016 E350 Wagon, 2013 S550 4Matic, 1985 280SL, 2005 Land Rover LR3
I have similar creaks in my 2013, only over certain asphalt patches and rough concrete or milled pavement. It sounds like it comes from the end of the door nearest the seatbelt anchors. It isn't too noticeable but I thought about getting it looked at next time its in for service. Based on your experience, I'm not optimistic it can really be fixed.
If it is coming from the seat areas and center console, spray leather conditioner on all the leather where they meets the plastic parts. Same thing was happening to my 07 when I got it recently and a friend of mine who works on these cars told me to do this, I did and it worked like a charm. I use Meguires Leather conditioner spray and let it soak in then wipe it clean.
