Tire size 4 matic to staggered.
hey guys looking to stagger the wheels on my 10 s550 4 matic with some factory reps in 20" perhaps. what is the correct staggered size?
The OEM staggered is a safe bet and looks proportional too as far as sidewall height, and the impact on ride quality is minimal vs 19's. Rubbing on the rears tends to be a rim offset issue rather than a tire tread block width problem.
A 9.5" on a 35mm offset (the typical replica offset) and OEM spec 20" rear tires should not rub. I'd say run those factory spec 20's on wheels with a 35mm (or greater) offset and you should be good to go.
OEM Spec is 275/35 rear and 255/35 front. That gives you a 2% variance in rolling diameter, well within the 3% margin of safety recommended for AWD staggered set ups.
Cool I'll look into those, did you get new sensors? Where did u get new lugs from? Just pulled the trigger on s63 reps.
Depends on the weather
These below are for 07-09. If your car is 10+ you need the 433mhz sensors.
http://shop.advanceautoparts.com/p/v...earchTerm=tpms
You can get lugs from amazon or ebay.
http://www.ebay.com/itm/20-BLACK-CONE-SEAT-LUG-BOLTS-14X1-5-THREAD-PITCH-28MM-SHANK/251775351512?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D29980%26meid%3Dbf6857125c944f4bbe12d0b0e7ba0f94%26pid%3D100005%26rk%3D4%26rkt%3D6%26sd%3D151414526744&rt=nc
I think I need 315hz like those say no? found them on ebay oem looks like for 85.00 shipped if there the correct ones. I guess I can test fit the wheels w my existing lugs when they come in, not sure how to tell if I need different lugs though? how r u getting 40-50% off at advance? looks like 15% off.
share the link please haha
i found one at amazon for about $130 for all four for my 2013.
Ebay has them also cheap.. I just hate waiting for shipping for things unless they can do overnight shipping so I pay the extra for local sales. :-)
Your lug nuts will be too long. They will screw in and once they get to a certain point they will stop and not sit in the hole, you will have space between the wheel and lug nut.
1 Post
2011 Mercedes S63 AMG
Its better to make sure... I thought I had those, bought and installed them, then I realized that I needed 433Mhz. Now I have the "tire pressure monitors inoperable" on my screen.
Just made an offer to the $85 ebay one. They accepted my first offer of $75. Seller respond was very fast too!
They dont have warranty on the tpms but they said they will take care of their customer
you sure?? I thought 10 up needed 315?
cool, I Ordered them looks like they will also accept 70.00!! Not bad. I also got a quote of 850 for conti dws installed from a local tire place so all in all think ill be under 2k for rims tires and sensors. Now I need some lowering links and akebonos!!!
