Dealer that can perform COMMAND firmware update
Old 08-14-2015, 03:07 PM
Chris51080's Avatar
S63
I'm in the San Jose area and need a recommendation for a dealer that is capable of performing the firmware update on my S63 that will enable birdseye map view and traffic on the navigation screen.
I already tried one at a dealer in walnut creek, and had no luck. They only sold me a navigation disc.
Old 08-14-2015, 03:57 PM
MBenz07's Avatar
2016 S550
Looking in Florida too
IF anyone knows of a dealer in central Florida, I'd like to get the update too
Old 08-14-2015, 06:07 PM
alx
alx's Avatar
I believe the command firmware updates are part of the Nav update disks. On n other words inserting a newer version of a Nav disk will update the firmware
Old 08-14-2015, 07:51 PM
Chris51080's Avatar
S63
That is not correct.
The firmware update is completely separate and done with the Mercedes star computer.
I have the latest navigation disc, and do not have the traffic or birdseye views.
Old 08-14-2015, 08:16 PM
WHPH28's Avatar
Depends on the weather
That is right. When I went through the pain of going to like every dealer in the area only te last one knew what they were doing. They all tried to sell me the dvd to update my navigation and not the actual comand itself...and they all said it was too risky, except the 4th one who was in the know about everything and they just charged me an hour of labor.
Old 08-14-2015, 09:39 PM
alx
alx's Avatar
Ah. You are asking about the firmware of the head unit. Yes, that is done via star/ das. There is also an alternative offline method with an update disk (not a Nav update one). However most dealers will shy away from doing it as it has a fairly high rate of bricking the head unit and then the dealer is on the hook for the replacement. The official posture is not to update if the unit doesn't exhibit freezes/ reboots.
Traffic also requires traffic- specific sirius subscription.
Old 08-14-2015, 09:47 PM
WHPH28's Avatar
Correct. They had to put on their service order that customer states it is freezing because they can't just update it with out reason.
Old 08-14-2015, 09:49 PM
alx
alx's Avatar
Buy your SA a case of beer.
Old 08-14-2015, 10:34 PM
Chris51080's Avatar
S63
So, since my command unit sporadically freezes, shows the MB logo and reboots, any dealership should be able to update to the correct firmware?
Is there a copy of the TSB explaining the procedure that I could bring in?
Old 08-15-2015, 01:10 AM
steveb9771's Avatar
2007 CL550
Traffic for 2007-2009 does not use Sirius for its data and doe not require a Sirius subscription. The data is provided via a signal contained in local FM radio station broadcasts. As a result of this method of delivery, traffic data is only available for areas within the local area (but that is all that really matters). Traffic data is free.
2010 and newer vehicles receive their traffic data via Sirius and require a special paid subscription.
Old 08-15-2015, 07:38 AM
mrbobby's Avatar
2003 S500 4Matic (SOLD) + 2004 S55 (SOLD) 2005 CLK 500 Cabriolet 2008 S 450
That's good to know. The traffic function in my '08 is rudimentary (no fancy graphics etc.) but functional. The unit tells you the local traffic condition and it's up to you to find the work around.
Old 08-15-2015, 09:27 AM
wilassasin's Avatar
2013 S550 4matic (AMG sport package), 2016 Corvette Stingray.
So now they have found a loop hole to require us the purchase Sirius as a functional way to promote the service. Gee, thanks MB
Old 05-25-2019, 05:21 AM
azontodance's Avatar
Mercedes Benz S550
Pls can you tell me the Disk option without star/das
Old 05-25-2019, 10:45 AM
konigstiger's Avatar
Received 4,411 Likes on 3,144 Posts
'71 Pinto
NTG3 Telematics CD part # 2218270665 strongly suggest using in conjunction with DAS.
Old 05-28-2019, 10:49 AM
kn51's Avatar
2007 S600
IIRC that is the only way possible. I updated mine and it was "fussy" with my DAS setup but it went through. Had to laugh at this because just yesterday I was plowing through my random download folder to clean up things and spotted the iso image for the updated telematics and it brought back memories.
Old 05-28-2019, 02:18 PM
domr's Avatar
2008 AMG S65
I bought a disc from the dealer but it's not working for me. Any chance you could share that iso? Thanks.
Old 05-28-2019, 02:43 PM
kn51's Avatar
2007 S600
Are you clear on what is required? Navigation map updates are basically inserting a disc and it will take a while for it to update.
The Telematics update requires a DAS system.
Old 05-28-2019, 02:53 PM
domr's Avatar
2008 AMG S65
Yeah, I have DAS and the disc I bought is 221-827-06-65-26. Maybe the -26 at the end of the part number is my problem.
Old 05-28-2019, 02:57 PM
kn51's Avatar
2007 S600
Yeah, that is the wrong part number.
Old 05-28-2019, 03:03 PM
'71 Pinto
Search “2218270665” to comparison shop upon which you will find 221827066526 is the current part #.
Old 05-28-2019, 08:50 PM
kn51's Avatar
2007 S600
Sorry, I stand corrected.
Telematics iso image i have is labeled 221 827 00 65.
Someone fat fingered it I'm sure.
Quick Reply: Dealer that can perform COMMAND firmware update
