parking lamp
Old 08-29-2015, 12:15 AM
gphil7's Avatar
s550
parking lamp
How to change the parking lamp on the left side?
Old 09-19-2015, 03:42 AM
john.cook109's Avatar
s class 320 cdi 2007
Just turn the steering wheel hard right. Then remove bolts holding front inner wheel arch cover 3? and peel back. You will need a rectangular shaped object (15mm x 10mm) inserted into the bulb retaining unit found tucked inside the arch and level with the light unit. Twist anti-clockwise to remove. When replacing the unit you can line it up by viewing through the light unit itself.
Old 09-19-2015, 06:08 AM
gphil7's Avatar
s550
I fixed it two weeks ago but thank you John Cook for your help. I ran into a new problem blower motor and regulator. A cost of $1015 but my dealer coupon of 30% cut the price down.
Quick Reply: parking lamp
