Sponsored by: DashLynx
Unusual rumbling noise in the dashboard when the climate control HVAC is set to REST?
Old 09-11-2015, 11:41 AM
ChesapeakeLimo's Avatar
2019 Maybach S560
I have this unusual rumbling noise when the climate control/HVAC system is set to REST or any temperature setting above LO.
http://youtu.be/eISENKwyrXU
Seems to be linked to the flow of heat? Could this be related to some issue with the heater water valve? Is there a recirculation motor on the valve assembly?
IDEAS?
Old 02-15-2016, 06:50 PM
2019 Maybach S560
UPDATE:
The rumbling noise was actually a gurgling noise coming from the heater re-circulation motor in the engine compartment at the firewall. Was a bit low on coolant. Topped it off and problem resolved.
Quick Reply: Unusual rumbling noise in the dashboard when the climate control HVAC is set to REST?
