Mercedes S550 2007 - Vibration idle
Dear All,
I need your support in finding the right issue with my car. the history goes like that
first i changed the engine oil then My car battery went dead (starter),I did the jump start and i changed the battery and once it was done i discovered that there is a slight vibration while idle in my car. seems like that there is one cylinder not working. though the car accelerates fine.
There is no engine light or any kind of error on the screen
i have my own obd and tried reading out the code and as per that i found the following using carly application
ID1: 6715BCD1-87B8-4491-AF90-48CCE38FA74C-1750-0000021ED4B1D326-aef 34-06-961 ID2: 550B4576-0766-41F9-B8CF-55BE975DC65B-1750-0000021ED
2015-10-06 17:34:06
BASE: Series 221 - S Class Limousine / Baureihe 221 - S Klasse Limousine
BUILD-YEAR: 2007
MODEL: all/alle (-)
FAULTS: 35
ECUs: 38
BATTERY: 14.2V
DEPTH: Enhanced communication
SPEED: normal
CONNECT: Fast Connection
VERSION: 9.1
DEVICE: >Syed Aley< >iOS<
WIFI: >WIFI327<
ELM: ><
COM+: >UNKNOWN<
0. Motor Control:
ME - Motor/Engine Electronics (MB: 0034462040):
- : Fault: Implausible data were received from control unit ''ESPregistered''. Implausible data were received from control unit 'ESPregistered'.
- Code: 001369
FSCU - Fuel pump AMG (-):
- ECU not present/no answer
FSCU_EC - Control unit ''Fuel pump'' (N118) (-):
SG-EM - Electric motor control unit (-):
SCR - Selective Catalytic Reduction (-):
1. ABS / DSC / Brake:
ABR - Adaptive Brake (MB: 2215452632):
- : Fault: No CAN message was received from control unit Engine control module or N15/3 (ETC [EGS] control unit). / Fault: No CAN message was recei
- Code: 006106
- : Fault: One or more signals sent from control unit 'Combustion engine' via the CAN bus is implausible. / Fault: Check codings in control module Eng
- Code: 007208
DTR - Distronic (-):
EFB - Electric parking brake (A13) (MB: 2214300649):
- ECU OK, no fault code
NBR-VL - Nahbereichsradar vorn links (B29/2) (-):
NSA - Night View Assist (N101) (-):
WSS - Weight sensing system (N110) (-):
SGR - Radar sensors control unit (-):
2. Airbag:
AB - Airbag (MB: 2218200985):
- Fault: No CAN message was received from control unit N73 (EIS [EZS] control unit).
- Code: 00919D
- Fault: No CAN message was received from control unit N10/2 (Rear SAM control unit with fuse and relay module).
- Code: 009198
- Code: 009199
- Fault: No CAN message was received from control unit A1 (Instrument cluster).
- Code: 00918C
- Fault: No CAN message was received from control unit N93 (Central gateway control unit).
- Code: 009195
- Code: 009193
- Code: 009194
- Fault: No CAN message was received from control unit Engine control module.
- Code: 009196
- Code: 009197
- Code: 009180
- Code: 009183
- Code: 009184
- Code: 009185
- Code: 009186
3. Transmission Control:
ETC - Electronic transmission control (MB: 0034460310):
4. Instrumentation:
COU [ZBE] - Central operating unit (MB: 2218212251):
HBF (Rear control panel) - Rear control field (-):
OCP - Overhead control panel (MB: 2218203226):
- Event: The control unit has been reset due to an internal error.
- Code: 009006
- Fault: Not Relevant!
- Code: 00C0E1
- Code: 00C0EA
KBE-H - Rear A/C operating unit (MB: 2218200385):
IC - Instrument cluster (MB: 2215400011):
- Event: No CAN message was received from control unit Transmission.
- Code: 00C01F
UCP - Upper control panel (MB: 2218201310):
OCP - Control module 'Panoramic sliding sunroof' (-):
5. Light/Rain Control:
XALWA-L - Xenon headlamp, left (MB: 2218709326):
XALWA-R - Xenon headlamp, right (MB: 2218709326):
6. Heating / AC:
AAC - Automatic air conditioning (MB: 2218700426):
- Fault: R41/4r1 (Left rear center air outlet potentiometer) : Short circuit to positive or open circuit
- Code: 0091A5
- Fault: R41/4r2 (Right rear center air outlet potentiometer) : Short circuit to positive or open circuit
- Code: 0091B5
STH - Stationary heater with remote control (-):
7. Immobilizer System:
KG - Keyless Go (-):
ASSYST Active Service System (MB: 2215405445):
- Fault: Control unit ASSYST is not receiving any messages from the interior CAN bus.
- Code: 008703
- Fault: Control unit ASSYST is not receiving any messages from the engine compartment CAN bus.
- Code: 008704
ASSYST PLUS (MB: 2215405445):
8. Park distance control / PDC:
PTS - Parktronic (MB: 2214420156):
PTS - PARKTRONIC (N62) (-):
9. Audio / Navigation / Communication:
DAB - Digital radio (-):
Left rear screen (-):
Right rear screen (-):
RFK - Backup camera (N66/2) (MB: 2218270545):
- Fault: Interior CAN communication has a malfunction.
- Code: 008601
ZAN - Central display (MB: 2218205989):
FU - DVD player (A40/4) (-):
COMAND (MB: 2218205726):
IHI - Mercedes-Benz InCar Internet (N125/3) (-):
MFK - Multifunction camera (A40/11) (-):
SDAR - Satellite digital audio radio (N87/5) (-):
VCS - Voice control (-):
B&O-SND - Sound system (N40/3) (MB: 2218206089):
Tuner - Standard tuner (-):
Tuner - Tuner sound (-):
TV - TV tuner (A90/1) (-):
UCI - Media Interface (-):
CTEL - Mobile phone adapter with universal interface (-):
DTA - TELE AID (-):
TELE AID - Telematic service Emergency call (-):
TELE AID - Telematic services Remote door unlocking , Remote door locking (-):
TELE AID - Telematic services MB Info , Roadside assistance ( USA, Canada ), Tele diagnosis ( ECE ) (-):
TELE AID - Telematic service Stolen vehicle tracking (-):
10. Systems:
Trailer recognition module - Trailer recognition (N28/1) (-):
SG-BMS - Battery management system control unit (-):
BNS - Vehicle power supply control module (MB: 2215457132):
- Fault: The consumer shutoff is active.
- Code: 009014
- Fault: Component G1/4 (Starter battery) has Undervoltage.
- Code: 009016
- Fault: Not Relevant! The contact of component N82/1k1 (Quiescent current cutout relay) does not open.
- Code: 009023
ISM - Intelligent servo module (MB: 1642700252):
EHPS - Electrohydraulic power steering (A91/1) (-):
EZS - Electronic ignition switch (MB: 2215450308):
- Fault: Undervoltage (local
2015-10-06 17:34:06
BUILD-YEAR: 2007
MODEL: all/alle (-)
FAULTS: 35
ECUs: 38
BATTERY: 14.2V
SPEED: normal
VERSION: 9.1
WIFI: >WIFI327<
ELM: ><
COM+: >UNKNOWN<
0. Motor Control:
- Code: 001369
- Code: 006106
- Code: 007208
2. Airbag:
- Code: 00919D
- Code: 009198
- Code: 009199
- Code: 00918C
- Code: 009195
- Code: 009193
- Code: 009194
- Code: 009196
- Code: 009197
- Code: 009180
- Code: 009183
- Code: 009184
- Code: 009185
- Code: 009186
4. Instrumentation:
- Code: 009006
- Code: 00C0E1
- Code: 00C0EA
- Code: 00C01F
6. Heating / AC:
- Code: 0091A5
- Code: 0091B5
- Code: 008703
- Code: 008704
- Code: 008601
DTA - TELE AID (-):
10. Systems:
- Code: 009014
- Code: 009016
- Code: 009023
2006 S430 4Matic
The thing that caused your problem was a disconnected battery. Any time you remove power from the vehicle most of the computers in the vehicle "reset" and when you apply power they don't go back to their normal working state. There are a series of resets you must do whenever you remove the power, including resetting the windows, wipers and many other accessories. If you take it to a dealer they will perform the normal resets. (or someone who knows what the resets are) If you have this done your car should start running normally. All you have to do is tell them you removed the battery.
