Airsuspension malfunction?
Mercedes S550 longwheelbase 2007 w221
Hallo ,
I drive a Mercedes S550 (S500=eu) long 2007. On the dashboard a error appeard. I want to know why it happend? I have looked at the car but all the side are equal(height).
Storing means malfunction in dutch
Zo niet check je airmatic pomp-relais mogelijk dat ie niet loopt ..
If you push the 'raise-button' on the cluster does the car actually raise itself?
If not check the airmatic-pump relay ,possibly the pump does not run..
Located at and more tips:
https://mbworld.org/forums/s-class-w221/493599-s550-air-compressor-fuse-relay-location.html
kingconn (03-17-2017)
Luchtvering/air suspension
Als je op de raise-knop drukt op het cluster,komt de wagen dan omhoog ?
Als ik over drempels ga hoor je wel de vering werken(gepiep en gekraak) heel lichtjes.
If i press the raise button the car rises and is stands equal.
Alvast bedankt.
