wrong Jumpstart
1 Post
w221 S63 2008, w221 s550 2008, w211 e200 2004, w210 1999 e320, w123 200
wrong Jumpstart
Hi,
My w221 2007 wont start, I tried to jump-start it and it went well but yesterday I wrongly connected the cables, I noticed the fuse (20A) was blown up, I had I new one and connected the car in the way then i tried to start it again and it kept blowing up the fuse again and again,-NOW IT WONT START-
any help please
any help please
Location: Land of Political Criminals and Urban Shootings
2015 S550
Hi,
any help please
any help please
1 Post
I've replaced the battery, bu I am afraid that I have short circuit because the fuse keeps blowing up,
any help please
and I checked the fuse box nest to the battery its fine nothing blown up or broken inside
any help please
You are generally screwed. Every reverse jump start I have seen resulted in a few and expensive components ending up dead. For starters you probably lost your front (maybe rear too) SAM as well as possibly your drive authorization and ecu. Starter relay. And it goes on.
A star reading will point some of the casualties. Others will have to be found via trial and error.
Good luck...
Good luck...
1 Post
do I need c5 star to check the car ?
why does it keep blowing the fuse?
and the car has everything working (everything) except starting the engine
Good luck...
Good luck...
1 Post
sadly no,
even the mechanic is not accepting my phone calls
but a friend told me I should disconnect the alternator
what do you think?
what do you think?
1 Post
the car has wiring harness we don't know where,
the mechanic checked the rear and front SAM and they are OK.
tomorrow I'll take the car back and send it from Dubai to Jordan to have fixed there.
