Sponsored by: DashLynx
Low beam fix 2012 221
Old 01-15-2017, 06:33 PM
Donnymac's Avatar
63 Falcon vert
Last week I found a very smart tech. Explained to him my night time low beam short distance concern. Long story short. Fixed!
Each headlight body has a single top side hex adjustment screw. Visable access easy. As explained to me, at 10' from a wall, low beam should be 36" above GL. Easy to measure. I was 27". Counterclockwise raises the light. Test drive tonight.
No STAR needed.
The following 2 users liked this post by Donnymac:
Magnus Rostadmo (09-27-2017), natcahd (01-16-2017)
Old 09-27-2017, 10:26 AM
Magnus Rostadmo's Avatar
S550-07 Obsidianschwartz A200Turbo-07 Kosmosschwartz C200T -10 Tenoritgrau
I also found this and have now adjusted my low beam.
But problem is it seems the main beam - which was approximately ok before the adjustment - is now way to high, almost in the treetops.
So i wonder, is it possible to tune the main beam down electronically via STAR ?
Old 09-28-2017, 01:27 AM
Donnymac's Avatar
63 Falcon vert
Good question. I don't know.
For me, the correct low beam adjustment was my primary goal. Elevated high beam actually helps spot wildlife at night on country roads. However, I keep the automatic dimmer engaged.
Old 09-28-2017, 06:59 PM
Jason B's Avatar
W140 Mercedes S350, W221 S550 sport
No STAR needed.
Any pic of this area where you adjust? Might help others if you have a visual... I did notice this the other night that the cutoff is a little low. Maybe I should raise.
Old 09-29-2017, 01:49 AM
Donnymac's Avatar
63 Falcon vert
As requested. 6mm hex Allen. Long. Short will not reach. Easy access both sides.
Attached Thumbnails Low beam fix 2012 221-img_0472.jpg   Low beam fix 2012 221-img_0471.jpg
Last edited by Donnymac; 10-29-2017 at 01:11 PM. Reason: Dan9100 is right. 6mm not 5mm. Fixed.
Old 09-29-2017, 01:24 PM
Jason B's Avatar
As requested. 5mm Allen. Long. Short will not reach. Easy access both sides.
Very cool! Thanks. So you are now are 36" above ground level? Thanks, can't wait to try this. Also, I think most cars have the driver side low beam slightly lower than pass.
Oh, I notice now when you first start the car, you can see the glass fish eye low beam move. I guess this is normal when it does it's leveling thing?
Old 09-29-2017, 03:36 PM
Donnymac's Avatar
63 Falcon vert
I adjusted to 36" and experimented from there.
Old 10-28-2017, 10:59 PM
dan9100's Avatar
CharlesStyncOB
Close-up of the allen caphead adjuster
This shows the direction of adjustment.
Down - Clockwise
Up - Counterclockwise
Thank you Donnymac for post. With your photos of the adjustment hole location I can see so much better at night time.
I would lke to add that on my 2011 S550 the caphead hex is a 6mm allen.
Quick Reply: Low beam fix 2012 221
