S65amg help???
S65amg help???
Hi everyone can anybody help??
I have bought myself a damaged w221 2009 s65amg.
Need help with wiring colours diagrams, for aux fan in wheel arch, also small radiator wire colours, extra water pump wire colours and layout, also a mysterious brown earth cable near the coolant bottle? Please help thanks in advance
S600xxl (02-16-2017)
Difficult to look that stuff up without star wiring, as you need to know what each piece is and then look it up by location. "small radaitor wires"? Which extra water pump, the intercooler pump?
Get yourself a copy of wis. Draw a pentagram on the shop floor and drive said s65 in the center of it. Sprinkle liberally salt on the perimeter of pentagram. Have a spray bottle with holy water so when you start tearing things apart you spray the creatures that come out the mangled assemblies. Repent. Use wis to anchor you to this world so your soul stays put when enticed to be sold in exchange of wiring diagrams that prove to be wrong in wis.
Good luck.
Good luck.
Thanks for your reply
Really need wire diagrams colours for these.??
Thanks ian
Location: Land of Political Criminals and Urban Shootings
2015 S550
If this happens, the best thing you can do to save yourself is to go look for a midget and an El Camino. Let aforementioned midget drive the El Camino while you ride shotgun. You need to have a tape of Herb Alpert and the Tijuana Brass playing Casino Royale at 80% volume with the windows down while the midget drives you around. This tactic has been known to fix many problems.
2015 S550
I believe a regular old midget will work in a pinch. If you can lure the midget to the El Camino with some bacon, you can take care of the problem relatively cheap. Of course, you need to borrower somebody's El Camino and make a tape of the previously mentioned song. A working tape deck in the El Camino is an absolute must!
The manual SPECIFICALLY states "Please use only Mercedes Certified Midgets when calibrating your S65 for pentagrams. USE OF NON CERTIFIED MIDGETS OR DWARFS CAN DAMAGE YOUR VEHICLE AND MAY VOID THE MERCEDES WARRANTY
btw, on a more serious note i just looked in wis. your wiring of interest is in there. i couldnt find the mysterious ground though.
I wouldn't worry about the aux radiator fan just yet. I bet most of them don't work anyway.
Aside from the loom between the ECU and the engine, there aren't THAT many wires in the engine compartment. My car is in parts (again), so I can help when its daylight again.
Definitely get an ebay copy of WIS and install it on your PC though.
Nick
Nick
Nick
Nick
Why aren't these things straight forward!!
What's up with your motor?
My tandem pump started to lose pressure, so I'm fitting a recon one. Big job.
Sorry, I realised that I have a different car to you. I was just hoping to offer a bit of support.
Apart from brakes, fluids & filters, nothing is very easy I'm afraid.
Nick
Nick
Good luck.
Good luck.
