Removing phone cradle
2010 Range Rover S/C 2010 Land Rover LR4 HSE Lux Plus 2007 BMW R1200GS
I would like to remove the phone piece under the right hand arm rest. I can see a couple of small phillip head screws, but I wondered if it was that easy, or might there be something else I have to do. The storage area is useless with this piece in place.
Any info would be appreciated.
LS7 powered Corvette
There should be two screws, one at the front facing the driver side. The other one is at the rear facing the rear. They should be a T10 torx bit. Remove the screws and then just pull it out.
If you have a phone installed, the cradle just comes out by depressing the tiny button next to the phone's retaining clip and sliding it rearward.
I guess my close vision isn't what it used to be, I thought they were phillips head.
thanks for the info.
