Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > S55 AMG, S65 AMG , S63 AMG (W220, W221)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
S55 AMG, S65 AMG , S63 AMG (W220, W221) Discuss the S55, S65, and S63 AMG.
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 05-03-2012, 07:57 PM   #1
DuaneC63's Avatar
Drives: AMG C63, Porsche 996TTX50
Head Bolt Failures
I don't know if any one here is following the issue with defective head bolts on the M156 engine. However I am cross posting this from the C63 board. All M156 up to a certain engine number are subject to this failure. MBZ-USA will not retro fit with the new head bolts until they fail (snap off) causing the head gasket to fail. Rapid loss of coolant into the cylinders(s) is the first indication of the problem. Failures usually occur between 40K and 50K miles. The cost to repair is very expensive if you are out of warranty. MBZ-USA has a service bulletin out on this but will not provide a copy to customers. If any of you have had this problem please send me a PM. I am pursing this further. I would suggest a letter writing campaign to:
Mr. Ralph Fisher
Mercedes-Benz USA LLC
Customer Assistance Center
Three Mercedes Drive
Montvale, NJ 07645-0350
Click the image to open in full size.
To remove this ad, register today or login if you already are registered!
__________________
Current
2003 996TTX50
2009 C63
2009 Lexus RS350 (wifeys car)
In Loving memory of my bank account
2006 X3
2005 C55
1999 C43
1997 M3 4Dr
1995 325 4Dr
1985 318i
1995 Porsche 993 RS
1985 Porsche 911 widebody
1983 Porsche 911 Cab
1980 Porsche 911
1978 Porsche 911
DuaneC63 is offline   Reply With Quote
Old 10-02-2012, 09:53 PM   #2
Drives: 280SL
Did you file a complaint to Mr. Fisher?
I just saw your message and I have the similar problem. I have a ClS 500 at 37,000 miles it has a "valve cover gasket leak". I have all of the required services done at authorized MB dealer. The dealer told me it is common because rubber gets old. Are you kidding me. The car is only 6 years old with less than 40k miles. It definitely a quality issue.
How did Mercedes respond to you?
Thanks.
drv2500 is offline   Reply With Quote
Old 10-04-2012, 11:08 PM   #3
Drives: 2008 ML350 1987 Buick GN 2000 Pontiac Grand Prix GTP 2006 Mercedes S65
There is a HUGE difference between a head gasket and a valve cover gasket. We used to see valve cover gaskets ALL the time. They are no big deal and if your a little handy you can save the labor and do them yourself. Last one I did took less than an hour for both sides.
The Head Gaskets are a cause for concern. If you need the bulletin from StarTech info let me know and Ill email it to you.
Good luck everyone.
mbelite1 is offline   Reply With Quote
Old 10-05-2012, 12:37 AM   #4
Drives: 280SL
Thank you for your information. I know very little about fixing car but I will ask my friend to help me. If possible please send me the bulletin. Very appreciate you spent the time to explain and reply.
Tags
amg, bolt, bolts, c63, defective, failures, fisher, head, headbolt, headbolts, m156, mercedes, problems, ralph, s63
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
