Car Rides Like A Tank - Any Ideas?
W220 S65 AMG
Gents, not sure where to start to diagnose it.
I know it needs new balljoints because it makes a squeak sound when going over bumps.
Recently it started to ride VERY harsh, like a freight train or a more so like a Panzer tank.
I can feel almost any variation in the road surface, every little crack and bump is felt very harshly through the car. The back seems to be OKAY, it's more so the front of the car.
Few things to note -
-It's lowered via SDS
-Needs balljoints
-Needs an ABC pulsation damper
-Stock wheels, 43/47psi F/R
Raising suspension up dampens some of the vibration, but not all of it.
It never rode like this until about a week ago.
-Needs balljoints
2005 S55, 2002 E430, 2007 CLK350, 1981 380SL
I would guess (from 560SEL experience) that the pulsation damper is completely shot...so there is no gas pocket at all to absorb the subtle bumps, or pressure spikes, in the system...on the older cars there was a split chamber for the fluid (that will not compresss) and the gas that would compress, to absorb the vibrations and small bumps. The older cars ride turned to stone when the accumulators went out.
I would replace the damper first then if you still have the issue, keep looking...a Rodeo might bi in order no matter what to open up the system.
Also make sure your "ABC Sport" mode is not on all of the time with the console button...
Good luck and keep us posted...
Mike
Mike
W220 S65 AMG
Mike
Mike
I have ordered the pulsation damper and it should be here tomorrow. I'll let you know what happens.
Ouch... I vaguely remember that happening to me but I got the car home and called my MB dealer and they picked it up. I've had so many suspension issues I can't remember what the fix was plus I don't understand what any of the parts mean. It did have something to do with ABC suspension even though I had no warning on the dash according to MB service rep who dumbs everything down to layman terms for me.
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Have you connected the car to STAR DAS for check the ABC error codes. If your ABS light is on or these is a fault in the ABC system it will cause the suspension to become very stiff.
W220 S65 AMG
Well.. it was the pulsation damper.
After the change, the car handles like brand new. So firm and responsive. The rough ride is completely gone.
It was very difficult to do it on jack stands so I found myself a lift and had it off in 2 minutes.
YOU DO NOT NEED TO BLEED THE LINES GOING TO THE STRUTS!
Let the car sit for about 10 minutes to make sure all pressure is out, lift it and undo the old pulsation damper with a 24mm wrench while holding the valve body with an adjustable wrench.
When you install the new damper, YOU MUST LEAVE the plastic shimmy tube inside, do not discard!
When done, verify fluid level in ABC tank and start the car. Perform the rodeo or about 5 minutes worth of up/down exerciser. Verify there are few to no bubbles on the ABC dipstick and you're good to go!
Here's the culprit:
and the new damper:
Here's the culprit:
and the new damper:
W220 S65 AMG
You can't pre-fill the new damper with fluid since the diaphragm is tight against the inlet.
Like I said if you let the car sit for about 10 minutes most of the fluid will be returned to the tank and you'll lose minimal amounts.
PLATINUM SPONSOR
Is there a Pulse Dampner for the rear too? The rear of my car is feeling really rough , unless I wore the struts out from so many hard launches.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
Im about to do the same with my car but im a little stuck.
Basically the car has gone kind of stiff and theres a humming noise when i drive it. Im replacing the pulsation damper in the hope that this will sort out the problem, but just want to clarify how to actually replace it without causing any damage to the rest of the ABC system.
There is talk of not letting the system ingest air whilst replacing the damper, and loosening a belt and priming the pump in another thread but no idea as to which belt to loosen and which pump to prime and how to do any of it.
https://mbworld.org/forums/s55-amg-s...-dampener.html
Id appreciate any help from yourself as the job seems easy enough but can also become a major pain if a procedure is missed?
Many thanks.
Many thanks.
Many thanks.
Many thanks.
My rear suspension feel hard on some bump, it actually sound clunky and i am about to change the rear pressure reservoir. I think my pulsation damper is good, the ride feel ok for the most part aside from the rear clunky noise over some bigger bump. The small bump feel ok it seem. I have no humming noise, therefore does it mean the pulsation damper is good. Sorry for all the question, but i just got the car a week ago and cant be sure how smooth they should ride.
Either way, i will soon find out after i change the rear pressure reservoir.
Thanks.
Ciao
Perfota
Its easy to change, you just need two pliers to rotate the pulsation damper off from the end of the pipes its on. One set of pliers on the pipes, and the other set on the actual damper itself. Hold the pipes in place securely, turn the damper with a good bit of force and hey presto, it should loosen itself off.
Once loosen, you should be quick to remove it and get the new one in place as quick as possible. Took us about 15 seconds and we lost about 10-15 drops of fluid in that time, so not a great deal. Make sure the white plastic bit stays in the new damper, do not remove it.
At a later stage i also changed the rear reservoir ball but i dont think that made much of a noticeable difference though. At this minute, i too get a clunk and a creak over bumps from the rear, but thats a subframe bush thats out, need to get that replaced. I suggest you get all the rear bushes checked before replacing anything on the back.
Hope that helps.
Only time will tell and some research
Ciao
Perfota
Do this little test first - Open the trunk, place your hands between the lights and push the car down quickly, like your making the back end squat quickly, to replicate it going over a bump. See if that makes any noises.
If possible, get 2 people to push it up and down several times and see what you come up with.
This is by no means a definitive test for anything, but may give you some idea as to where the noise is coming from. Everytime i do it i can hear the creak from the left side right underneath the strut.
Do this with the car started, and then with it turned off.
