wheels offset
Old 02-13-2013, 09:26 PM
hotgreek's Avatar
2004 S 55 AMG
wheels offset
I've been trying to buy the right wheels for my 2004 S 55 without luck So far i change 3 set of whhels and lost so much money. All of them rubbing the rear fenders .Anyone knows the offset for this car ? My last set is Mandrus made for mercedes benz but bs. Same thing rubbing in the rear ..not all the time but ...any ideas ?
Old 02-14-2013, 08:48 AM
mrbenzes's Avatar
2005 S55, 2002 E430, 2007 CLK350, 1981 380SL
The stock ET is 44 for the front and 44-46 for the rear (depending on the year)...these are for the W220 S55 and S65 cars.
Mike
Old 02-14-2013, 08:28 PM
w4sim's Avatar
S55K AMG
Mike
Yeah that sounds about right.
I was taking a bit of a gamble when i ordered my wheels as they were described as 35mm offset, however when they turned up they were 45mm offset and went on with just millimeters of clearence on the rear when i lowered the car. Im pretty sure the 35mm ones would have caught the rear arch.
Old 02-14-2013, 08:42 PM
hotgreek's Avatar
2004 S 55 AMG
thank you guys Any idea where to buy rims from ? I need something with a lip in the rear and Not $ 5000 thanks
Old 02-15-2013, 07:01 AM
Zax63's Avatar
2006 s65. Ford Excursion 6.0. Pontiac GTO convertible. Porsche 944 Turbo SCCA car. Wife-E550 and 968
Mike
This is incorrect. The stock rear ET for a w220 s65 is 60et. I had 18" custom drag wheels made with a 55 so I could fit a slightly wider rim, but it is close and depending on the rubber you get a tiny bit of rubbing on the inside with 285's. the inside of the stock rim is stamped 60et. The aftermarket rim companies did not believe me so I took photos and measurements.
Old 02-17-2013, 11:03 AM
hotgreek's Avatar
2004 S 55 AMG
Any one seeling any wheels 19 ? I find out the truth that to put nice wheels and fit 100 % on my car i have to spend $ 5000 .. I can do it right now 2nd baby on the way lol ...I have to look for someone who sell wheels second heand...If someone has any info let me know THANKS
Old 07-13-2014, 09:24 PM
CottRD's Avatar
1999 ML430, 2007 SL55 (fully optioned including P30 package), 2006 S65, 2010 S65, 2016 S550
Correct, 44 offset for the front and 60 for the rear on staggered rims for an 06 S65. These rim are different in width but both are 19" in diameter.
Quick Reply: wheels offset
