Top 1/4 times for the V12 TT 600 and the 65?
Old 04-10-2014, 02:08 PM
kamilclk430's Avatar
W215 V12TT Build by Speedriven, W221 S550 4Matic
Do you guys know what are the top quarter mile times for the V12 TT 600 and the 65. I believe there was a S600 on spray that holds the record for the 600 going 10.5xx in the 1/4. Not sure what the record was for the 65 other than that Renntech CL65 that went 10.2
It would be good to know what a stock turbo real record is, I want to see how close I can get to that record and after the turbos in June see what else I can do as far as records go.
Any input would be great the more info the better.
1/4 Time MPH 60FT CAR DRIVER
10.274* 137.460 1.626 Mercedes-Benz CL65 AMG RENNtech SGC
10.585* 132.460 1.610 Mercedes-Benz S600 RENNtech Nitrous Stephen F. Selden
10.660* 120.120 1.545 Mercedes-Benz CL600 Joseph Barrett
10.725* 128.080 1.575 Mercedes-Benz CL65 AMG Speedriven V12Godspeed
10.730* 130.860 1.660 Mercedes-Benz CL65 AMG VRP Marko
10.732* 129.010 1.657 Mercedes-Benz SL65 AMG ATPTURBO Emma @ ATPTURB
10.790* 127.320 1.575 Mercedes-Benz CL65 AMG RaceHorse
10.836* 128.270 1.620 Mercedes-Benz SL65 AMG RENNtech SGC
10.853* 124.929 1.583 Mercedes-Benz SL65 AMG RENNtech Lou Fishgold
10.927* 128.150 1.658 Mercedes-Benz SL65 AMG CBTuning.net Lane Freeman
Old 04-21-2014, 08:08 PM
PLATINUM SPONSOR
Exotic-metal55's Avatar
2003 CL55
Seen some stock S65 `s post 11.4s with just drag radials.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old 04-25-2014, 11:15 PM
BenzBoy12's Avatar
1988 535i 5 speed
Wow, really? 220s or 221s? I'm guessing 220s...
Quick Reply: Top 1/4 times for the V12 TT 600 and the 65?
