2006 S55 AMG exhaust smells like rotten eggs!!
After a hard throttle pass, my exhaust has a rooten egg smell and with my hand I can only feel heat and not much exhaust pressure exiting the muffler tips! Could this betime to replace the catalytic converters? Where are they located on the exhaust? What kind should I go with?
PLATINUM SPONSOR
I have OEM converters if you need some with low miles. Just PM me.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
