Bit of an emergency - need serpentine belt route diagram ASAP.
Hello all
2004 S55 Kompressor - same engine as CL55 Kompressor
The Serpentine/Auxiliary/Fan belt (which ever you want to call it) has come off my car. Got the problem solved, got a new belt, and now i dont know how it goes back on.
Any diagrams or pictures would be very much appreciated coz the car wont move until the belts back on.
What is the most right-most lowest pulley in that picture?
I think I need to change that pulley due to a bad bearing. But I forget what that is. Didn't want to have to remove the belly pan to peek.
Again, lowest point and furthest to the right....?
As above, thats the AC pulley.
Good chance the bearing has failed on that, as it did on mine, and you can purchase the pulley separately from Mercedes, but its a lot of fun to change. Keep a "swear jar" next to you if you plan on doing it yourself.
