S 55 2006 fuse #78 blowing
S 55 AMG compressor
I have S55 AMG 2006 fuse #78 keeps blowing can’t find which device is blowing the fuse. Any advice is appreciated.
The car worked fine parked at home and that was it. Could not start the next day.
I am trying to disconnect and eliminate the problem, but so far I only located and disconnected connector for the vipers. I have seen some info about voltage - ignition transformer, but not sure how it applies for S55 2006 with compressor.
FUSE # 78 Adjustable steering column, Anti-theft alarm, Cruise control, Engine management unit, Ignition lock, Steering column module, Steering wheel heating and Windscreen wipers.
