Transmission jerk/lurch
Howdy, I am having an issue during cold weather start ups where the transmission lurches after the 1 to 2 shift during the converter lock up. It does it again during the 2 to 3 shift but is more mild after that. I have searched the forums and several have had the same issue but thy never seen to post the solution. If you let off the gas it feels like it is directly coupled like a stick shift. After 5 minutes or so wh it warms up, it shifts totally fine. I assume one of the solinoids is sticking in the valve body.
My guess is something is telling the converter to lock up ant the incorrect time.
A fluid and filter change by the dealership did not help.
Suggestions?
Suggestions?
1 Post
2006 S55 AMG
Wouldn't hurt to check the mount. My mount looked fine, no rips, but still had hesitation. Other than that, from what I have found, hard shifting is normal in these cars in the cold.
While I don't have the exact same issue, I notice that I have a 2-1 downshift hard jerk when in Sport mode and when it's cold. Once I get into the drive for about 5-7 minutes, it seems to go away. But it is a hard downshift in Sport on cold mornings. Wonder if it's related to your issue?
This ^^^^^^^
When were the transmission mounts last replaced
Most people do not give their car time to warm up
in cold weather - I let it warm up until the idle
drops to normal
drops to normal
The Trans mount is fresh and a fluid change did not help. After reading about the same issue in the 275 section it appears to be the TCC PWM solenoid.
I am working on getting the torque converter clutch solenoid now. Hope to see if that fixes it. Will update in a week or so.
It even does it in manual. If you hold it in first it bangs hard when the converter locks up. When you shift to second it lurches again. A bit softer in third and much more mild into fourth. I think it tapers off because the gear splits are so much tighter in the higher gears. It is definitely an issue with the lockup function in the converter.
FlightTest I have the exact same issue with my W221 S65. Torque converter locks up very abruptly when cold, and then the issue disappears once the car warms up....which takes 6-8 miles. I had my Indy reflash the transmission module which helped the issue, but it still hits too hard (just not quite as hard as before) when the car is cold. Please keep us posted with your results.
