W220 Airmatic Suspension Data
I am under-graduation student need some information for my graduation project
i make test rig for w220 Airmatic Suspension using front w220 Shock Absorber but i need just two information
1- is the Value of air pressure supply Shock Absorber constant or variable and what is these value or the range of these value ??
2- voltage value of damping valve ??
Shock Absorber
damping valve
Shock Absorber
damping valve
'99 and '05 E55 AMG
1. Five (5) Bar. 73.5 PSI.
2. 12 volts or 0 volts. On or off. Binary.
http://www.mercedestechstore.com/pdf...2007-31-02.pdf will help you to define parameters that allow you to reach a conclusion for presentation.
