S55 amg gear problem (2003)
When I set off in the car it changes gear normally from 1st to second at low revs and then up to gear 4 it stays in gear for longer than it should. It's similar to when you used to have a choke on an older car and it over revved. I have taken it to a couple of approved garages locally but they cannot find a problem when plugged in to the computer. Does anybody have any info on this problem. Thanks pete
It's only ever driven at reasonable speeds and after a long drive it's the same but that method sounds like it's worth a try so I'll let you know how I get on. Thanks for the advice
