Strange smell on acceleration?
1 Post
2005 AMG S55
I'm in a 2005 S55. When I hammer the throttle I get a slight wiff of a burnt smell in the cockpit. Is that normal. No smell any other time, only when I lay into it.
Since you like to hammer it
You might also want to change
the Supercharger oil as it is most
likely the original oil from the factory
Thank-You
D.B.
Thank-You
D.B.
1 Post
2005 AMG S55
Good thinking D.B. but the guy I got it from within the last three years replaced the pulley bearing, belts, blower coolant pump, and oil. Must just be the belt slipping a bit.
1 Post
2005 AMG S55
Thanks, I think I will start with changing the supercharger oil. This belt has less than 15k on it and I think it should be good. I'll look into changing the oil and then update.
I would also check for any leaks
on any lines / seals
around / on the supercharger
Might be a very small pinhole
that on WOT may spray a
small amount of oil which
is what you are smelling
Thank-You
D.B.
Thank-You
D.B.
1 Post
2005 AMG S55
Thanks for the tip D.B. I will consult the star service library and see if I can figure out how to check for this. I have a fair amount of mechanical experience but this car will be a challenge. Thanks again for the encouragement.
