01 s55 with 4 codes p0500 p0720 p0700 p0715
Old 02-21-2016, 11:02 PM
slowgt's Avatar
2001 s55 amg
i just picked up this 2001 S55 as a project and im getting these 4 codes p0500 p0720 p0700 p0715. Im not able to drive the car since the abc has failed in the rear any help where to start with the codes i would appreciate it
Old 02-22-2016, 07:38 AM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
The 700 faults are issues with the transmission that are also picked up by the ECU--you can read and erase the ECU faults but you need factory or equal software to read and write to the transmission (TCU) to list the problems with the transmission--you got a BA expensive project!!
Old 02-22-2016, 12:46 PM
slowgt's Avatar
2001 s55 amg
I got a friend that is going to read the tcm for me I hope it is something simple like the conducter plate
Old 07-17-2016, 12:04 AM
mtclimber's Avatar
95 E300, 02 C230K, 12 GL350
I got a 00 ML55 AMG and the same thing is happening. After 10-15 min drive the BAS/ESP, ETS,ABS, brake pads, check engine and brake light come on. The Speedometer stops working and the transmission goes into limp mode. Have you found a solution to your problem? My cheap scanner pulls codes P0720 and P0500.
Quick Reply: 01 s55 with 4 codes p0500 p0720 p0700 p0715
