Potential 2013 S63 AMG Owner - Questions
Old 08-04-2016, 11:05 PM
RalphSmithIII's Avatar
2013 S63 AMG
I haven't been on these forums in a few years, after owning a 2010 C63, 2009 ML63, and a 2012 S500. But, I wanted to ask some general questions regarding the 2013 S63 AMG. I'm in the market for one and wanted to ask a few questions.
The first is regarding the P30 (I think) performance package. Is it strictly a bump in HP/TQ, assumingly provided by a different factory tune/ecu calibration? Does anything else come with that package? Additionally, if one was to go with an aftermarket tune, that would essentially negate the need to find an S63 with the package unless I happen to find one with?
The second question is, is there anything particular I should be looking when purchasing a used 2013. Upgrades worth waiting for, known issues with this year/car, etc?
The third involves buying an extended warranty. I believe 2013's still can fall under CPO which may leave 1.5ish years left. However, it seems that the general consensus is to purchase an extended warranty, which from what I've found can cost around $5400 for 2-3 years/24000 miles. Although these cars come with a ton of power, I'm still interested in throwing a basic tune on it, (Renntech, AMS, Weistec, etc) which unassumingly will void the warranty, unless there's something I should know otherwise.
So far I'm looking for the upgraded stereo system although admitting I haven't heard one before as well as simple things like blind spot assist.
Any insight/thoughts/suggestions would be awesome. I'm still combing through this forum to find some of the answers I'm looking for
Old 08-08-2016, 07:32 AM
Manofsteelpt's Avatar
S63
Hey bro, I can help a little bit... The P30 will tune out to the same as the non P30. I kinda wish I had the Bang system, tho I never heard it, I'm guessing it's great. My 13 was CPO and I bought the additional 2 yrs unlimited miles for $4200. Gave me close to 4 yrs from purchase time.
I talked to Weistec and Renntech, both companies claimed MB would not be able to tell if the car was tuned or not.
Hope this helps, GL in ur pursuit.
Old 08-08-2016, 11:06 PM
2013 S63 AMG
Yeah, man that helps out a bit.
I've got my eye on a 2012 and 2013, almost identical across the board just need to wrap up selling my car then I can pull the trigger. I really want to jump into a '14 but I'm betting that they drop in prices, similar to these, in another 6-months to a years tops. So maybe the logical choice is to jump into a 2012-2013 for a bit then upgrade to the 2014's.
Old 08-09-2016, 03:43 PM
Former Vendor of MBWorld
RENNtechHQ's Avatar
Mercedes-AMG
--> PM send
Old 09-11-2016, 07:47 PM
fritza2tt's Avatar
1987 300D Turbo, 2007 ML63 AMG
2012 S63 AMG
I recently acquired a black 2012 S63 AMG with almost 95,000 miles on it. Inside and out in show room condition. Don't know how this was possible - even the windshield is original! I am grateful that everything on it works, it's loaded too, and I am not about to change anything on this car - just will enjoy looking at it and puttering around in the neighborhood. By the way, the manual says that if you are out of gas and all you can get is regular, it's ok to fill it half up, just don't rev over 3,000 RPM and don't his the gas pedal more than 3/4 of the way. This engine, the way it is, is perfect. You can putter along at 40 mph with the engine turning at 1,100 rpm running perfectly smooth. If you don't go bonkers and stick to speed limits, you'll never exceed 3,000 RPM! And with a 10/1 compression ratio, you even do not need to buy high test! :-)))
Old 09-14-2016, 12:50 PM
S63
We don't buy AMGs to putter around town at 1100 rpms.
a100steaksauce (09-20-2016)
Old 09-14-2016, 01:42 PM
fritza2tt's Avatar
Manofsteel, it takes no brains to spend money! :-))) You can do all you want to do if you have enough loot to buy one new and still have it under warranty. But there is more to a fine car like this, like appreciating what it truly is, all the beauty and technology that is in it, without going WROOHM, WROOHM all the time. :-))) Personally, it's enough for mme to be able to look at an S63 AMG, touch it, smell it, listen to the engine purr and be able to say it is mine. :-)))
Old 09-14-2016, 01:58 PM
S63
Who said anything about money???
Sounds like you should've saved some money and bought a S550, or, maybe even just a poster of the S63. :-)))))
Old 09-14-2016, 03:49 PM
fritza2tt's Avatar
2007 ML63 AMG AND 2012 S63 AMG
Manofsteel, It’s not about money, it’s about appreciating what was possible to acchieve by the AMG engineers. Like my 2007 ML63 AMG. It has a naturally aspirated racing engine that puts out 503 HP and turns as high as 7,200 RPM. It’s now almost 10 years old, has 125,000 miles on it, looks like new inside and out. (Even still has the original wind shield!) That’s how I aim to keep the 2012 S63 AMG, with only 95,000 miles and also running and looking like new. I’m an old licensed airplane mechanic. It’s not easy to find these jewels, even for someone like me.
I had the ML63 for 2 and half years and the S63 for a month. I would not want to part with either of them. 
Old 09-14-2016, 04:18 PM
S63
Oooooooook.... Enjoy ur S63 at 1100 rpms.
And the original windshield on the ML too??? I didn't know these things get replaced that often that ur bragging about it being original.
Old 09-14-2016, 05:16 PM
fritza2tt's Avatar
Manofsteel, you are young and still have a lot to learn. When you are looking at a car with a 100K miles on it and the paint and the windshield are original, not chipped or cracked, it gives you a clue bout the previous owner. Leased car usually don't fare that well, that's something to be considered is it not? And if an engine operates smoothly and is able to pull the car at 1,100 RPM and 40 MPH, that's almost as good as a dynamometer test, is it not? Same thing with fuel consumption. If you are able to duplicate the specs or do better, that will put your mind at ease too, won't it?
Old 09-14-2016, 05:21 PM
S63
I think ur old and you think you've learned it all.
Enjoy ur S63 with original windshield... Next time, save the coin and just buy the poster.
Old 09-20-2016, 10:07 AM
freakuvnature88's Avatar
2013 s63 amg sedan
😂😂😂😂😂 @Manofsteelpt your killing me. Buy a poster. Ha.. so true tho..
andyncLI (02-22-2017)
Old 09-22-2016, 11:02 PM
2013 S63 AMG
Well this thread headed a little south....=)
I did end up picking up a 2013 S63, Black with Black Carbon interior and upgraded B&O stereo. Single FL owner, 36k miles with remaining CPO plus I bought the additional 2-year just in case. I typically don't keep cars longer than 1-2 years but since its refundable and transferable it just made sense.
When I got it back home I found out the rear was partially blown so it just got replaced and wow what a difference. Looking to pick up a nice set of 21's or 22's to get the look I'm after but overall very happy with the car. I originally was looking at this one as a stepping stone into a 2014+ S63 when they came down to the 80k range but after seeing how the new info system works in the newer cars, I'm now leaning towards keeping this one a little longer until I figure out which route I'll take next.
The idea of 4Matic with updated interior/exterior was the draw for me towards the newest gen but the way this generation looks both inside and out also does it for me.
I'll probably throw a 8.9 channel amp + DSP (Audison) on the upgraded stereo as its amp just seems a bit weak for the speakers unless you REALLY crank up the volume. May also consider a fully-integrated K40 setup since my MB dealer is a preferred installer for it but that'll come after I pull the trigger on the wheels. I'll also have the dealer powercoat the brake calipers MB/Brembo red to set some contrast to it as well as clean up the current paint (silver/grey) that looks like someone spilled brake fluid on them in a few small places.
If I keep the car for a longer haul than expected, and the warranty runs out of I don't worry about it, I'll consider a stage 1 turbo upgrade since these motors, trans, rears appear to be capable of handling that level of power. And, considering there's no need to upgrade the fuel system that seems like a good time in this huge sedan =)
Quick Reply: Potential 2013 S63 AMG Owner - Questions
