S55 DASH LIGHTS COME ON BUT THE ENGINE WONT CRANK
2004 S55 AMG
HI I HAVE A 2004 S55 THE CAR WAS SMOOTH TILL I TRIED STARTING IT 2 DAY AGO WHEN I TURN THE KEY ALL THE DASH LIGHT WERE CAME ON BUT THE ENGINE WOULDNT CRANK AND NOT THERE NO POWER IN THE CAR AT ALL I CANT EVEN LO OR UNLOCK THE DOORS I TRIED BOOSTING IT POWER COMES ON WHEN I CONNECT THE BATTERY WITH MY OTHER CARS BATTERY BUT THE CAR STILL WONT CRANK AND AS SOON AS I STOP BOOSTING IT CUTS ALL THE POWER AGAIN PLEASE HELP ME OUT....
2004 S55 AMG
at first i could turn the key and all the dash light came on but it was just not cranking but now there's no power in the car at all its just like i have no battery i cant even open the door i have to use the little metal key to unlock my trunk or the drivers door but still no power at all
maw1124 (08-19-2016)
2004 S55 AMG
Boosting these cars can cause weird electrical problems. slow charge the battery overnight, then if it still holds a charge after being dead flat, start the car and check voltage while it's running to see if the alternator is working. If you're in a hurry, drop in a fully charged battery to check it.
If you lose all power, you have a discharged or bad battery. Fix that first.
Jumpstarting these cars is not easy, they require a ton of initial power to start and if the battery is weak it won't work well anyway. Just get the battery replaced and see what happens.
'06 MB S55 AMG; '04 Audi Allroad 4.2; '05 BMW M3 Conv.; '92 MB 500E
But a 40min charge means nothing on these power hungry beasts.
Good luck.
maw
Did you ever resolve this problem? I'm currently in a bind. Just picked up a 2001 s55. I knew it had little problems that I'd be able to fix, but this one has got me in despair. Set aside all the other problems, after work I put some stuff in the trunk. I noticed some ticking noise on the left side of the trunk. I see there's some loose wires so I gently pulled them out to make sure nothing was grounding out by separating them. Continued to put my items in the trunk and went to start the car. Same exact thing as you descibed. Except for one thing that u noticed. After getting power to the car and turning the key it would make a clicking noise as if it was the starter. Just not as loud like on other cars. Besides what are the odds of my starter going bad at the same time my battery dies out. This is just the tip of the nightmare I'm going through. Sorry for jacking your thread. I'm just looking for answers for the exact problem you were having.
