2006 transmission service for S55 tutorial ?
am at work right now so im blocked with proxies left and right,does anyone have links on how to change the fluid and how many quarts i need ?
im assuming i need the gasket,filter,tranny oil. anything else ? does the pan have 1 screw to drain the fluid or 2 ?
thanks in advanced guys
remove drain bolt, drain fluid. Remove all bolts from pan, carefully there still more oil
change filter and clean pan, install gasket.
you also need dip stick to check fluid at engine warmed up
