Would it be possible - throttle body question
88' twin turbo R supra
If I made a custom intake manifold to run 2x stock TB's on my s65amg with the wires spliced so the computer thinks it is only controlling one, 2x would simply draw more amperage.
It would be possible but it is not just a splice.
There is a feedback sensor on the throttle to recognize blade position. I believe it uses a potentiometer with a voltage reference. At a minimum you would need diodes to prevent cross feed through from one to the other. It could probably be a simple discreet circuit but I would need to look at the schematics to be certain.
Problem with that is the ECU still sees the current draw from the TB, so if you run two and it requires twice as much power to open them, at full throttle it will exceed what the max should be. It may cause a limp mode type issue or a panic closing of the throttle.
There's always a way around it though, if you get creative enough. There are stand alone options now which would be able to handle it, but they are not cheap.
What are you trying to setup with the dual throttles?
Because the stock intake manifold and TB are garbage for an engine easily capable of 1000hp, it is setup like a chevy vortec truck engine that is about 40% efficient. Look at the M137 V12 or the M120 intake manifolds.
If your configuration allowed them to be close together, you could remove the spring from one and physically link them together.
shardul (01-10-2017)
The problem comes when the drive motor on the throttle which is not referenced starts to fail - then you are essentially running it open loop with an improper transfer function (do not confuse with fuel/spark open loop, not the same thing).
I assume, as most ECUs do, it looks at voltage drop across the motor circuit, which has a known resistance, and calculates amp draw using Ohm's law. The only actual current measuring i've seen is done on battery/alternator systems with actual ammeter rings around the cables or in the battery control modules.
https://mbworld.org/forums/w211-amg/...-kit-55-a.html
Interesting idea, but I think it would require modification of the manifold and Y-tube.
