S63 AMG 4MATIC Coupe, S65 AMG Coupe (C217), Convert. (A217) 2014 -2021
Driver Side AC Vent Airflow
Old 12-01-2016, 11:24 PM
RJC
RJC's Avatar
Question Driver Side AC Vent Airflow
Is it normal for the driver side ac vent to have significantly stronger airflow/output than the passenger side with all controls set to same settings? I was told this is also the only ac vent that has the ionization.
I've also noticed the airflow from the rear ac vents is pretty weak...are you guys finding the same?
TIA
Old 12-02-2016, 12:46 PM
Plutoe's Avatar
Received 1,022 Likes on 950 Posts
1999 E300TD
You are listening to the wrong folks----take the car,late in the day, to any dealer and any service tech will fully explain your AC system!!
Old 12-02-2016, 01:19 PM
RJC
RJC's Avatar
What exactly are you referring to? The drivers ac vent IS the only vent that the ionization comes through according to my manual and no one told me the stronger flow from the drivers vent was normal...I was simply asking if it was.
Quick Reply: Driver Side AC Vent Airflow
