Bluetooth - Microphone quality
I recently installed my puck with tail in my 2003 E320. Works great, however the party that im speaking to says that it sound like my voice sounds "muffled".
The quality of the incoming voice sounds great through the comand/speakers.
Does anyone else have an issue with microphone quality? My comand has the latest s/w btw.
JM
JM
2020 E450 Coupe, 2022 Porsche Macan, 2001 Porsche 911
I'm using the puck with tail very successfully. I have asked people to tell me how I sound on the other end, and I've been told that it does not sound like I'm on any hands-free system. The microphone is in the rear view mirror, and I have a tendency to try to point my voice in that direction, which might be the reason...
I spent the last couple hours reading all Puck with tail posts.
It seams that our 2003 E class dont have a MHI (didnt come out until 2005). We have the CP211 Module (which is part of the teleaid).
So if my sound quality from the microphone is very poor, is this something that is fixed with a software update to the CP211?
Anyone?
John
Anyone?
John
GL350
It is mostlikely the phone you using..I tried the KRZR ,RZR ,PBL, and Siemens
Siemens is far the best of all for me.
What kind of phone are you using John?
Im using a Sprint Blackberry 8703e (based on some comments, i am updating my BB f/w to latest now)
I will also try a Treo and Razr tonight to see if it sounds better...
My BB works, just the microphone quality sucks...
John
John
Received 4,414 Likes
'71 Pinto
For MY03 and 04 the Microphone Voice Control Module (MIC CM - A35/1) needs to be replaced with part #BQ6820929 to resolve echoing, high-pitched noises, and general distortion. You can reference DTB P-B-82.70/338b.
Thanks that sound interesting, is Q6820929 part of the rear view mirror where the microphones are? or is that a separate thing in the trunk area?
EDIT - I dont have a Voice Control Module, where i can issue voice commands to change the radio etc. My 2003 is stock..no V60 installed phone. I just installed the puck with tail, and did the version coding. Thats it.
John
John
'71 Pinto
EDIT - I dont have a Voice Control Module, where i can issue voice commands to change the radio etc. My 2003 is stock..no V60 installed phone. I just installed the puck with tail, and did the version coding. Thats it. John
John
'71 Pinto
Oh, so to just clarify, i need to replace my (A2118204226 or A2118202485) with the updated one?
And i should mention the DTB P-B-82.70/338b ?
Is it just a swap out? or is there version coding needed?
Thanks very much for your input..
JM
JM
'71 Pinto
Simple process, out with old in with the new - no coding.
Does anyone have the ability to pull and or print this TB? So I can see if this is a DIY thing? I asked my MB dealer, however they have not returned with a answer yet.
DTB P-B-82.70/338b
JM
DTB P-B-82.70/338b
JM
'71 Pinto
C320 CDI Estate, E500 4M Wagon
Konigsticker,
Confused on your earlier post - if a M/B did NOT come with the phone package, does it still have a mic? So all that's needed is the wiring bit in the center console, the bluetooth puck, and a reflash?
Thanks,
Smash
Thanks,
Smash
Kudos to Konigsticker
John
'71 Pinto
Yes, the microphones at the base of the interior rear view mirror are utilized for MBUSA TeleAid and the phone. In this case, the 211 discussed has been prewired from the factory for phone install.
Ah, makes sense with the emergency recovery system. I'm thinking of doing the phone add-in, seems very simple. Thanks for the info, now I need to search for those 2 part numbers again...
Smash
Smash
I spoke to my MB SA, he advised to get a appt and bring her in!!!
My feeling is that they are going to cover it under warranty...
She goes in next Monday!!
JM
JM
The part # upgrades to A211 820 6185
I have one ordered and will change it myself.
John
'71 Pinto
If I understood you correctly, you are out of warranty less than 30 days. A quick phone call to MBUSA CAC 800-367-6372 may override the dealer’s decision and approve a goodwill repair. Even though the part installs easily, keep in mind if you receive a goodwill repair and a problem should present itself during repair or after it will be resolved in the process. Furthermore, your dealer’s service/repair policy (i.e.: 90 days, 1 year, etc.) will extend the warranty period at no cost.
'13 E550 W4
I recently had the bluetooth puck installed. At first, the sound coming in was fine, but the outgoing voice was reported to sound like I was in a tube or under water. Then, the microphones went out completely although I could still hear incoming voices. "Hello, can you hear me now...??" No dice. Dealer is fixing now by updating the mic modules, along with fixing my SBC.
'71 Pinto
